lightningew
lightningew
Post by meteoesine » Sat Oct 01, 2022 11:29 am
at the beginning of each month the last strike resets to 1 January 1970 without having reset either the gw1100 or the meteobridge
furthermore,
Would it be possible to move the 'total lightning year' under Strikes last 60min and above last strike?
but only total lightning, however
the other comments $tunder_txt (Storm is approaching at, Storm is going away, ...) leave them under where they are
thanks in advance
many thanks in advance
Re: lightningew
Post by andyk1 » Sat Oct 01, 2022 11:26 pm
Your lightingew block ver 2.4 is not showing any data as of right now. Is the ecowitt (Ecowitt WH57 Lightning Settings)
Show last strike timestamp ( false=delta true=timestamp ) = True
Show total strikes in current year = True Turned on?
Re: lightningew
Post by meteoesine » Tue Oct 04, 2022 6:37 am
the device works well and regularly detects lightning strikes (when there are :-), the problem I noticed is that at the beginning of each month the data resets showing the last strike on 01/01/1970
I cannot understand if it is a problem of the lightningew block, or the gw1100 gateway or the meteobridge.
I set 'Show last strike timestamp' to false (it is not consistent to display the last strike in 1970)
regarding the total strikes, I was wondering if it was possible to make a change to the block, inserting the total strikes in the lightningewBlock.php instead of in the lightningewupdater.php in order to have it aligned with the number of hourly and daily strikes.
regards
Julius
Software: meteobridge
Re: lightningew
Post by Julius » Tue Dec 26, 2023 2:34 pm
andyk1 wrote: Sat Oct 01, 2022 11:26 pm Your lightingew block ver 2.4
Where did you get ver 2.4 ??
Re: lightningew
Post by davidefa » Tue Dec 26, 2023 3:37 pm
I have updated this post to include the last version of the block
