graphCombined -New Dec 2 2024 problem SOLVED
Sarah R Taylor
- Software: I hope to use a Meteo-Pi
The block graphCombined suddenly stopped working today, Dec 2 2024 on my website: https://www.owlsheadns.com/template/indexDesktop.php
with no changes from me or from my ISP that I can see. The demos at: https://www.meteotemplate.com/web/blocks.php (and select graphCombined) are also not working.
I looked both using Firefox on Win 11 and Chrome on Android.
Last edited by Sarah R Taylor on Tue Dec 03, 2024 1:42 pm, edited 1 time in total.
- lemimi
Re: graphCombined -New Dec 2 2024 problem
Good evening,
Maybe try the latest version updated by Davidefa here:
https://www.meteotemplate.com/forum/vie ... =25#p13572
Michel
Michel
Sarah R Taylor
@lemini Thank you for the suggestion I try Davidefa's new version but it would not install for me. Perhaps I need instructions of exactly how to install Davidefa's version. I started this new thread because it seemed to me that my current problem was not like the one that Davidefa set out to solve.
It seems you have not correctly updated the block as I can still see the 'map error' on your site ( verify that the graphCombinedBlock.php script is the one included in ver 3.0, Dec 02 2024 ):
- map_error.png (75.45 KiB) Viewed 27117 times
Sarah R Taylor
Thanks to both people who responded. I tried again to install the latest version of the block from a few days ago and it seems to be working. I think I know what my mistake was last evening. I tried to have both the old and the new version running, with different names, but it seems that didn't work. So I put the new files in the directory where the original files were (I made a backup copy) and removed an old "setup.php" file before doing Edit Settings.
I guess I will never know why the old version worked until it didn't. My hosting provider made no changes as far as I can tell. My sites are running with PHP Version 7.4.33.
Re: graphCombined -New Dec 2 2024 problem SOLVED
I think it has something to do with a higcharts change ( as the error refers to a nonexistent highcharts.map function which was previously working )
- Jolumarali
- Station model: Vantage Vue
- Software: WlIP
Glad to see you again Davide and thank you again, Everything is working properly and thank you all
Alvaro Poggiani
- Software: Meteobridge Pro2
Sono nuovo e inesperto ma, come altri, volevo esprimere anch'io la felicità di poter ri-leggere i consigli e le "istruzioni" di Davide che, pur conoscendolo solo per le gentili parole di benvenuto, ho potuto -cercandolo e leggendolo- apprendere e capire molte problematiche da lui risolte precedentemente.
Meglio viaggiare sapendo che un faro può sempre indicarti dove andare...
Grazie ancora e, forse, in anticipo
Alvaro
https://meteovarazze.it
Alvaro
