Current conditions wrong info
spd2612
Software: Meteobridge Pro 2
Post by spd2612 » Thu Dec 04, 2025 6:51 pm
What have I missed my current conditions block is fine except for forcast it is still getting the forcast from florida and im in Ar now
Got to be a stting i missed somewhere after my move
Davis Pro 2
Meteobridge Pro2
GW 2000
WH57 Lightning Detector
FSC830
Re: Current conditions wrong info
Post by FSC830 » Mon Dec 08, 2025 4:09 pm
You mean the 3rd block at your page?
Headlines "Today - Current Conditions - *Forecast* - Station Data - ..."?
Which block/plugin is that?
Did you check in setup section if there is some value to set (or modify)?
spd2612
Post by spd2612 » Mon Dec 08, 2025 4:40 pm
Yes i have checked the block
And lon and lat is correct
No other settings
Got to be something in the file I have reverified the settings was hoping someone one else had the issue
In current conditions
It is still reporting my old location in flordia
Davis Pro 2
Meteobridge Pro2
GW 2000
FSC830
Post by FSC830 » Mon Dec 08, 2025 5:54 pm
Did you check forecast block?
What lat/lon values are in ../pages/forecast/cache/current.txt?
Do they match with your current coordinates?
spd2612
Post by spd2612 » Mon Dec 08, 2025 5:56 pm
Yes i have
Davis Pro 2
Meteobridge Pro2
GW 2000
FSC830
Post by FSC830 » Tue Dec 09, 2025 11:11 am
From where do you get the forecast data, openweather map?
spd2612
Post by spd2612 » Tue Dec 09, 2025 4:15 pm
There is a link in the block in cp but its just lat and long
It is not current conditions block it is the summary block that has the wrong data
Under the tabs
You can see how wrong that data is
Davis Pro 2
Meteobridge Pro2
GW 2000
FSC830
Post by FSC830 » Thu Dec 11, 2025 9:31 am
The Summary block uses yr.no for getting the forecast data.
Did you configure it with the correct string: "United States/Arkansas/Craighead/Jonesboro" ?
