Not able to view bloomsky timelapse block
Fraggboy
Software: Bloomsky
Post by Fraggboy » Tue Oct 03, 2017 4:34 pm
Hello.
So, I have traced it down to running the site via https. As of now, it's showing a strange error (Shown below).
I have tracked it down to the bsCache.txt file. The URL's to AWS is http. When I replace all to https, it works great. I checked bloomskyTimelapseBlock.php and changed all http to https. It breaks the block.
Does anyone know of a way to modify the code so when it updates the text file, it uses https?
Fraggboy
Software: Bloomsky
Re: Not able to view bloomsky timelapse block
Post by Fraggboy » Tue Oct 03, 2017 9:17 pm
So, I have come up with a workaround for now. I created a simple script that finds and replaces http with https every 30 minutes via cron.
sed -i 's/\bhttp\b/https/g'  bsCache.txt
The videos are showing up correctly on my page.
EDIT: Had to modify the code a bit.
Fraggboy
Software: Bloomsky
Post by Fraggboy » Thu Oct 05, 2017 1:59 pm
So, my script modifies the time/date stamp check in bloomskyTimelapseBlock.php.
if(file_exists("cache/bsCache.txt")){
		if (time()-filemtime("cache/bsCache.txt") > 60 * 60) {
			unlink("cache/bsCache.txt");
I am at a loss in how to get this fixed.. :(
EDIT: I have modified my cronjob to every 60 minutes which is working good now.
Post by Johnny » Thu Oct 05, 2017 4:00 pm
Hi Christopher, just to let you know that your Bloomsky video is visible right now, I'm guessing you've gone back to HTTP mode. I think this is going to be one of those questions for Jachym to answer.
Orbie and Stormie Bloomsky.JPG (29.19 KiB) Viewed 24572 times
Fraggboy
Software: Bloomsky
Post by Fraggboy » Thu Oct 05, 2017 5:05 pm
Johnny,
I modified the cron job to run every hour since I believe the script checks for modification every 60 minutes.
I need Jachym's assistance.
Post by Jachym » Thu Oct 05, 2017 7:31 pm
If you just echo the raw output of the API do you see everything ok?
Fraggboy
Software: Bloomsky
Post by Fraggboy » Thu Oct 05, 2017 8:42 pm
The API data is correct. It's just that all of the requests to amazon are http. When I modify it to https it works great.
As of now, my cronjob is working much better since I have it run every 60 minutes.
