Interactive Sticker (Trivial) - Missing Millmeters when set to DualUnits
- MonyMony
When I have my sticker set to use the DualUnits=1, I have noticed I am only showing Inches (my primary units) but not mm. I see metric measurements for the other parameters so not sure why rain would be different. Is this by design?
- Screen Shot 2017-10-09 at 1.22.16 PM.png (685.9 KiB) Viewed 9749 times
Re: Interactive Sticker (Trivial) - Missing Millmeters when set to DualUnits
This is indeed strange.... I dont really see how that can be happening given the other ones are showing ok. I will look at the code tomorrow
Found the issue, please update the plugin to the latest version.
- MonyMony
Updated, and not seeing any millimeters. Is this due to no rain today or something else?
However either way it should show at least the unit label, it is the exact same code as for the other parameters
- MonyMony
Manual, after auto took too long (did not see your note initially). Let me for everything to overwrite in case something strange happened and see if that makes a difference.
This really makes no sense since it is the exact same line as for the temperature for example and even if the number for some reason didnt work, it should at least show "mm"
Never mind, I see the issue, I will update it tomorrow again. There was a typo and I just noticed it was used twice in the script and because I copy/pasted it the typo got carried over to the other line too.
- MonyMony
No worries and certainly no rush.
Thanks!
Thanks!
- MonyMony
Thanks Jachym... confirmed this issue is resulted with v7.2 of the Stickers plugin.
Jay
Jay
