Offline
stadelhofen
Station model: Davis Vintage Pro 2
Offline
Post by stadelhofen » Tue Oct 31, 2017 6:02 am
Hi everybody
I moved my site from one provider to another. New is, that the page is https://
https://meteo.ksstadelhofen.ch
The Database shows actual data, everthings seems just fine, but the webpage shows OFFLINE.
What do I have to change in the configuration, that the station shows ONLINE again?
Many thanks to all of you
Michael
Re: Offline
Post by Jachym » Tue Oct 31, 2017 9:33 am
Try the Check for errors, several blocks dont work, looks like maybe file_get_contents is disabled. Also check your server time.
stadelhofen
Re: Offline
Post by stadelhofen » Tue Oct 31, 2017 12:18 pm
how do I enable file_get_contents?
Re: Offline
Post by Jachym » Tue Oct 31, 2017 12:22 pm
Does it show in Error check that it is off?
stadelhofen
Re: Offline
Post by stadelhofen » Tue Oct 31, 2017 3:37 pm
how do I do that?
stadelhofen
Re: Offline
Post by stadelhofen » Tue Oct 31, 2017 7:26 pm
I assume, that since I can't donwload nor update Blocks, because I get the Errormessage: Failed to extract block ZIP file my problem is, that I have to check the rights on specific folders.
is there an overview, which folder has to have specific rights?
Re: Offline
Post by Jachym » Tue Oct 31, 2017 8:14 pm
All folders must be writable
stadelhofen
Re: Offline
Post by stadelhofen » Thu Nov 02, 2017 5:24 am
all folders are now writable, the systemadministrator was a little confused, thet the site is vulnerable.
But I still get the message OFFLINE.
The database shows all data.
The message: Last update: 2017-10-29 18.54
https://meteo.ksstadelhofen.ch/template ... esktop.php
Re: Offline
Post by Jachym » Thu Nov 02, 2017 9:33 am
Do you update the database directly? Because the live conditions file is not being updated, look:
https://meteo.ksstadelhofen.ch/template ... teLive.txt
That timestamp is from Oct 29
stadelhofen
Re: Offline
Post by stadelhofen » Thu Nov 02, 2017 9:58 am
I don't know how the data is beeng updated. I have the database connection which I aded in the Mainsetup. When I test the Databaseconnection, I get the message: Your MySQL is currently set up correctly.
But where this data is written I have no idea. Yes off course I would preffer live data. Where should I change that?
I get an error message from Meteobridge.
Bildschirmfoto 2017-11-02 um 08.23.09.png (28.41 KiB) Viewed 12524 times
stadelhofen
Re: Offline
Post by stadelhofen » Thu Nov 02, 2017 10:08 am
would you recomend to reinstall the whole tempate instead searching for the error?
Re: Offline
Post by Jachym » Thu Nov 02, 2017 10:26 am
what is the URL you used in the MB setting, the screenshot is cropped, I cant see it
stadelhofen
Re: Offline
Post by stadelhofen » Thu Nov 02, 2017 10:45 am
Re: Offline
Post by Jachym » Thu Nov 02, 2017 11:00 am
I think the problem might be in the https because if I run the API manually, it works, but seems like MB is not calling it
stadelhofen
Re: Offline
Post by stadelhofen » Fri Nov 03, 2017 9:17 am
PROBLEM SOLVED
It was a DNS Issue.
