SteelSeries Gauges
ckoebke
SteelSeries Gauges
Post by ckoebke » Sun Dec 31, 2017 12:11 pm
Hello all,
i have a problem with this plugin. It always tell me that there is an parse error in the json object. You can see the error here:
https://www.koebbes.de/wetter/plugins/s ... /index.php
Hope you can help me.
Thanks and regards,
Carsten
ozgreg
Station model: DAVIS 6163
Re: SteelSeries Gauges
Post by ozgreg » Sun Dec 31, 2017 12:21 pm
The problem is in the generation of your Steelgauges JSON file
This is what mine looks like most likely your missing a variable so the JSON import is failing..
{"date":"23:19:45",
"dateFormat":"d/m/y",
"temp":"17.3",
"tempTL":"11.6",
"tempTH":"31.2",
"intemp":"23.8",
"dew":"13.2",
"dewpointTL":"",
"dewpointTH":"",
"apptemp":"20.2",
"apptempTL":"20.2",
"apptempTH":"20.2",
"wchill":"17.3",
"wchillTL":"",
"heatindex":"17.3",
"heatindexTH":"17.3",
"humidex":"20.2",
"wlatest":"0.0",
"wspeed":"0.4",
"wgust":"3.1",
"wgustTM":"7.2",
"bearing":"121",
"avgbearing":"121",
"press":"1010.1",
"pressTL":"1008.0",
"pressTH":"1014.6",
"pressL":"",
"pressH":"",
"rfall":"0.0",
"rrate":"0.0",
"rrateTM":"",
"hum":"77",
"humTL":"",
"humTH":"",
"inhum":"53.0",
"SensorContactLost":"0",
"forecast":"Conditions updated: 23:19:45",
"tempunit":"C",
"windunit":"km/h",
"pressunit":"hPa",
"rainunit":"mm",
"temptrend":"-0.5",
"TtempTL":"06:11",
"TtempTH":"16:15",
"TdewpointTL":":",
"TdewpointTH":":",
"TapptempTL":"00:00",
"TapptempTH":"00:00",
"TwchillTL":":",
"TheatindexTH":"n/a",
"TrrateTM":"00:00",
"ThourlyrainTH":"00:00",
"LastRainTipISO":"n/a",
"hourlyrainTH":"0.0",
"ThumTL":":",
"ThumTH":":",
"TpressTL":"16:57",
"TpressTH":"00:10",
"presstrendval":"-0.1",
"Tbeaufort":"F0",
"TwgustTM":"18:45",
"windTM":"7.2",
"bearingTM":"121",
"timeUTC":"2017,12,31,12,19,45",
"BearingRangeFrom10":"359",
"BearingRangeTo10":"0",
"UV":"0.0",
"UVTH":"10.9",
"SolarRad":"0.0",
"CurrentSolarMax":"0.0",
"SolarTM":"",
"domwinddir":"ESE",
"WindRoseData":"[0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0]",
"windrun":"0.0",
"version":"3.5",
"build":"11744",
"ver":"10"}
Post by Jachym » Sun Dec 31, 2017 12:53 pm
The gauges also compare today´s data with yesterday. It looks like you have no data for yesterday. If that is the case just give it 24h and tomorrow it will work fine.
ckoebke
Post by ckoebke » Sun Dec 31, 2017 1:52 pm
Jachym wrote: Sun Dec 31, 2017 12:53 pm The gauges also compare today´s data with yesterday. It looks like you have no data for yesterday. If that is the case just give it 24h and tomorrow it will work fine.
OK, will see if it works tomorrow :) thanks to both of you
