Hello all,
i have a problem with this plugin. It always tell me that there is an parse error in the json object. You can see the error here:
https://www.koebbes.de/wetter/plugins/s ... /index.php
Hope you can help me.
Thanks and regards,
Carsten
SteelSeries Gauges
ozgreg
- Station model: DAVIS 6163
Re: SteelSeries Gauges
The problem is in the generation of your Steelgauges JSON file
This is what mine looks like most likely your missing a variable so the JSON import is failing..
{"date":"23:19:45",
"dateFormat":"d/m/y",
"temp":"17.3",
"tempTL":"11.6",
"tempTH":"31.2",
"intemp":"23.8",
"dew":"13.2",
"dewpointTL":"",
"dewpointTH":"",
"apptemp":"20.2",
"apptempTL":"20.2",
"apptempTH":"20.2",
"wchill":"17.3",
"wchillTL":"",
"heatindex":"17.3",
"heatindexTH":"17.3",
"humidex":"20.2",
"wlatest":"0.0",
"wspeed":"0.4",
"wgust":"3.1",
"wgustTM":"7.2",
"bearing":"121",
"avgbearing":"121",
"press":"1010.1",
"pressTL":"1008.0",
"pressTH":"1014.6",
"pressL":"",
"pressH":"",
"rfall":"0.0",
"rrate":"0.0",
"rrateTM":"",
"hum":"77",
"humTL":"",
"humTH":"",
"inhum":"53.0",
"SensorContactLost":"0",
"forecast":"Conditions updated: 23:19:45",
"tempunit":"C",
"windunit":"km/h",
"pressunit":"hPa",
"rainunit":"mm",
"temptrend":"-0.5",
"TtempTL":"06:11",
"TtempTH":"16:15",
"TdewpointTL":":",
"TdewpointTH":":",
"TapptempTL":"00:00",
"TapptempTH":"00:00",
"TwchillTL":":",
"TheatindexTH":"n/a",
"TrrateTM":"00:00",
"ThourlyrainTH":"00:00",
"LastRainTipISO":"n/a",
"hourlyrainTH":"0.0",
"ThumTL":":",
"ThumTH":":",
"TpressTL":"16:57",
"TpressTH":"00:10",
"presstrendval":"-0.1",
"Tbeaufort":"F0",
"TwgustTM":"18:45",
"windTM":"7.2",
"bearingTM":"121",
"timeUTC":"2017,12,31,12,19,45",
"BearingRangeFrom10":"359",
"BearingRangeTo10":"0",
"UV":"0.0",
"UVTH":"10.9",
"SolarRad":"0.0",
"CurrentSolarMax":"0.0",
"SolarTM":"",
"domwinddir":"ESE",
"WindRoseData":"[0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0]",
"windrun":"0.0",
"version":"3.5",
"build":"11744",
"ver":"10"}
{"date":"23:19:45",
"temp":"17.3",
"tempTL":"11.6",
"tempTH":"31.2",
"intemp":"23.8",
"dew":"13.2",
"dewpointTL":"",
"dewpointTH":"",
"apptemp":"20.2",
"apptempTL":"20.2",
"apptempTH":"20.2",
"wchill":"17.3",
"wchillTL":"",
"heatindex":"17.3",
"humidex":"20.2",
"wlatest":"0.0",
"wspeed":"0.4",
"wgust":"3.1",
"wgustTM":"7.2",
"bearing":"121",
"avgbearing":"121",
"press":"1010.1",
"pressTL":"1008.0",
"pressTH":"1014.6",
"pressL":"",
"pressH":"",
"rfall":"0.0",
"rrate":"0.0",
"rrateTM":"",
"hum":"77",
"humTL":"",
"humTH":"",
"inhum":"53.0",
"tempunit":"C",
"windunit":"km/h",
"pressunit":"hPa",
"rainunit":"mm",
"temptrend":"-0.5",
"TtempTL":"06:11",
"TtempTH":"16:15",
"TdewpointTL":":",
"TdewpointTH":":",
"TwchillTL":":",
"TrrateTM":"00:00",
"ThumTL":":",
"ThumTH":":",
"TpressTL":"16:57",
"TpressTH":"00:10",
"Tbeaufort":"F0",
"TwgustTM":"18:45",
"windTM":"7.2",
"bearingTM":"121",
"UV":"0.0",
"UVTH":"10.9",
"SolarRad":"0.0",
"SolarTM":"",
"domwinddir":"ESE",
"windrun":"0.0",
"version":"3.5",
"build":"11744",
"ver":"10"}
The gauges also compare today´s data with yesterday. It looks like you have no data for yesterday. If that is the case just give it 24h and tomorrow it will work fine.
