template hosting problem
evetsmd
- Station model: Davis Pro2, Model 6153
does the template only function in the root directory of your host server.......I have tried to run the template from a folder in the root and the pages don't load properly.......my ISP says it's my problem.....
Thanks for any help!
Steve
Steve
Re: template hosting problem
Hi Steve,
it runs perfectly fine from a folder and I would even recommend doing so, on Linux servers it does not work properly in root (icons). Make sure you have the path correct.
- meteocaldas
- Language Admin
- Station model: OS WMR-88A
- Software: Cumulus
Hi Jachym, I was planning to move MT to the root of my server, so the users will just need to type meteocaldas.com instead of meteocaldas.com/mtp.
My idea was to make MT the entrance of the site, so now I m a little confused.
Is there a way that users simply tipe meteocaldas.com and enter MT right away, without MT beeing on the root?
download this file, change the extension from .txt to .html and save it as index.html in your server root.
Before you do it, change the "template" inside that file to the name of the folder you use (mtp)
http://www.meteotemplate.com/web/wiki/index.txt
- meteocaldas
- Language Admin
- Software: Cumulus
Thank you sooooo much Jachym!Jachym wrote: ↑Sat Dec 16, 2017 6:04 pm download this file, change the extension from .txt to .html and save it as index.html in your server root.
It worked like a charm... and I never thought it could be so easy
You are a genius!
(I am not leaving it working by now, because former index.htm was from Cumulus and now I want to transfer all cumulus files to a different folder and update all the old links to realtime.txt... and to avoid any probems, I first need to create a backup and study the problem a little better, etc, etc.)
Once again thank you so much for this fantastic way to solve my problem!
ChrisBoom
Thanks Jachym, the small forwarding file works much faster than the internal forwarding settings of my ISP, which randomly kills CSS for (equally random) files.
evetsmd
Jachym.....Happy New Year.....
quote"it runs perfectly fine from a folder and I would even recommend doing so, on Linux servers it does not work properly in root (icons). Make sure you have the path correct."quote
I'm back on this issue again....I believe my ISP is using Linux Servers and I'd like to have meteotemplate work from within a folder on my root.....
Can u help me with how the path needs to be setup....right now I hv meteo setup in a folder called "meteo"
where do I set the path and what should the path look like....
Thanks for the help
Steve
Thanks for the help
Steve
- jay_hoehn
- Language Admin
- Station model: Vantage Pro 2 Plus
- Software: WeeWx
Steve,
Have you done the initial setup? As you follow down the setup page there is a place to set the path. If your meteo folder is one step below the root then enter /meteo/ Under that just put the URL of your site leaving off the /meteo/.
Jay
Jay
evetsmd
Thanks Jay....I think I have it under control
http://www.bwsrh.com/meteo/indexDesktop.php
Happy New Year
Steve
Happy New Year
Steve
- jay_hoehn
- Language Admin
- Software: WeeWx
Great, Steve. Good start to the site.
Happy New Year to you.
Jay
Jay
evetsmd
Thanks Jay....problem now is my "current conditions" shows offline....I would guess that it's not seeing my clientraw file from WD.....I can't remember where in MT if I need to set a path for MT to go get the clientraw file....
I know it's uploading to my ISP because my original wx website is working OK www.bwsrh.com
any ideas...thanks
Steve
any ideas...thanks
Steve
evetsmd
Hi Jay....I got it....needed to update the api folder in Weather Display.....I should have remembered that!
Steve
Steve
- jay_hoehn
- Language Admin
- Software: WeeWx
Steve,
Glad you got it sorted. Are you using the WD MeteoTemplate API upload?
Jay
Jay
evetsmd
Yes it seems to work well...
next step is to upgrade to 17...I need to find what it takes to do that.... there may also be a bugfix
that was done on 16 that I think I need to do before the upgrade to 17...not sure I fully understand this process.
thought I remember reading that each fix or update has instructions in the zip but I'm missing it somewhere...
Appreciate ur help..... thanks
Steve
Steve
- jay_hoehn
- Language Admin
- Software: WeeWx
Steve,
Here is a link to the instructions to upgrade:
http://meteotemplate.com/blog/?p=3549
Here is the link to get a download token:
http://www.meteotemplate.com/web/download.php
Make sure you request an update token.
Jay
Jay
- Ken Good
I was having a similar issue whereby my web page was not loading correctly when the web address was entered as "www" instead of "http." The home icon would be missing and there would be weird random letters or numbers in places. It was driving me crazy. It was a little frustrating. If I just entered the address as "BullardWeather.com" without anything else it was fine. I believe I fixed the issue using the text file referenced. I made one small change.Jachym wrote: ↑Sat Dec 16, 2017 6:04 pm download this file, change the extension from .txt to .html and save it as index.html in your server root.
<meta http-equiv="refresh" content="0;url=http://BullardWeather.com/template/index.php" />
This forced every address entered to be converted to the simple "BullardWeather.com address with the new folder added. So far any variation is changed and works fine.
pascalg21
- Station model: Davis pro 2
- Software: weatherlink ip
I have the same problem as you
I tried your site the problem is still there with the www address
ok avec http:://
ok avec http:://
- ea7gt
- Station model: WMR-180
I originally installed meteotemplate on a folder with no problems, then I decided to move to the root of a new hosting with domain and had a problem with the icons folder (404 error). Then I moved the template to a subfolder (eltiempo) and ask to the server for the problem with the icons folder and they fixed it. In this moment the template still in the eltiempo folder, redirected with a index.html but I think am going to move everything to the root only for a cosmetic reason of the URL showed in address bar.
Besides icons folder, is there any other trouble installing template on root?
