Forecast block not populating
Lewiston
I installed the forecast block earlier this week. To date it has not populated with data. Today I renamed the files in the forecast/cache folder. The current.txt was re-created shortly after being renamed.
Lewiston
Re: Forecast block not populating
Sorry, forgot the link: www.mooseberryhollow.com
Based on the error in the console it seems like you entered some strange things in the Forecast block setup, in particular with regards to quotation marks.
Please note, when I say for example:
use "wu" for weather underground
The "wu" is in quotes only to show that this is the exact phrase to enter, but what you need to enter in such case is simply
wu
not
"wu"
Could that be the problem?
wu
not
"wu"
Lewiston
That was it. Thank you!
- Dehatter
- Station model: Ecowitt WH80
- Software: Ecowitt GW1000
It seems like you have not entered a default forecast provider, or the one entered is not available. I can see the forecast if I change the provider.
Lewiston
Thanks for the heads up. Should be working now. I had a typo.
