Forecast block not populating
Lewiston
Post by Lewiston » Sat Jan 13, 2018 11:24 pm
I installed the forecast block earlier this week. To date it has not populated with data. Today I renamed the files in the forecast/cache folder. The current.txt was re-created shortly after being renamed.
Lewiston
Re: Forecast block not populating
Post by Lewiston » Sat Jan 13, 2018 11:25 pm
Sorry, forgot the link: www.mooseberryhollow.com
Post by Jachym » Sun Jan 14, 2018 9:31 am
Based on the error in the console it seems like you entered some strange things in the Forecast block setup, in particular with regards to quotation marks.
Please note, when I say for example:
use "wu" for weather underground
The "wu" is in quotes only to show that this is the exact phrase to enter, but what you need to enter in such case is simply
wu
not
"wu"
Could that be the problem?
Lewiston
Post by Lewiston » Sun Jan 14, 2018 1:57 pm
That was it. Thank you!
Post by Dehatter » Sun Jan 14, 2018 10:21 pm
It seems like you have not entered a default forecast provider, or the one entered is not available. I can see the forecast if I change the provider.
Lewiston
Post by Lewiston » Sun Jan 14, 2018 10:41 pm
Thanks for the heads up. Should be working now. I had a typo.
