Jachym,
The time seems to have stopped appearing on this block. It was working last night but when I looked this morning it isn't there. The time on the Steel series block is still working. I deleted the block and reinstalled to no avail.
Jay
Current Block
Re: Current Block
Hi Jay,
do you have any problems with the wind dir sensor? I think that is causing it. Either way, it should not, it should be able to deal with this. Please email me in 3-4 days when things calm down a bit and I will look at it.
- jay_hoehn
- Language Admin
- Software: WeeWx
Re: Current Block
Well that was strange. As I was looking at the home page it just showed up. Weird. Call it a gremlin for now.
- jay_hoehn
- Language Admin
- Software: WeeWx
Re: Current Block
Jachym,
Just wanted to let you know that you were right. It seems that the wind cable was not making good contact. I removed the cable and plugged it back in and it has been working since. Thanks for looking at it. You are the master.
Jay
Jay
gsiemon
- Station model: Davist Pro 2
- Software: Meteobridge Pro
Re: Current Block
Hi Jachym,
My Wind sensor is down, pending a relocation so I'm now seeing that the time is not showing on the Current Block. If you have a few minutes, can you let me know what needs to be fixed in the code?
Greg
Greg
Re: Current Block
I need a link to your page and also make sure you have the latest version
Re: Current Block
It is missing info about the bearing and this makes the script fail without continuing (thus not loading the time). Once your wind direction is working it will be fine.
