Current Block
jay_hoehn
Software: WeeWx
Current Block
Post by jay_hoehn » Sun Dec 31, 2017 2:47 pm
Jachym,
The time seems to have stopped appearing on this block. It was working last night but when I looked this morning it isn't there. The time on the Steel series block is still working. I deleted the block and reinstalled to no avail.
Jay
Re: Current Block
Post by Jachym » Sun Dec 31, 2017 2:52 pm
Hi Jay,
do you have any problems with the wind dir sensor? I think that is causing it. Either way, it should not, it should be able to deal with this. Please email me in 3-4 days when things calm down a bit and I will look at it.
jay_hoehn
Software: WeeWx
Re: Current Block
Post by jay_hoehn » Sun Dec 31, 2017 2:59 pm
Well that was strange. As I was looking at the home page it just showed up. Weird. Call it a gremlin for now.
jay_hoehn
Software: WeeWx
Re: Current Block
Post by jay_hoehn » Sun Dec 31, 2017 9:11 pm
Jachym,
Just wanted to let you know that you were right. It seems that the wind cable was not making good contact. I removed the cable and plugged it back in and it has been working since. Thanks for looking at it. You are the master.
Jay
gsiemon
Station model: Davist Pro 2
Software: Meteobridge Pro
Re: Current Block
Post by gsiemon » Tue Feb 27, 2018 9:53 am
Hi Jachym,
My Wind sensor is down, pending a relocation so I'm now seeing that the time is not showing on the Current Block. If you have a few minutes, can you let me know what needs to be fixed in the code?
Greg
Re: Current Block
Post by Jachym » Tue Feb 27, 2018 9:58 am
I need a link to your page and also make sure you have the latest version
gsiemon
Re: Current Block
Post by gsiemon » Tue Feb 27, 2018 10:02 am
Hi Jachym,
Fully up to date: https://ascotweather.com.au
Re: Current Block
Post by Jachym » Tue Feb 27, 2018 10:30 am
It is missing info about the bearing and this makes the script fail without continuing (thus not loading the time). Once your wind direction is working it will be fine.
