mchd17
Anyway to change station.png to my station image (davispro2.png) within all the menu images? I guess I could hack the code a bit, thought I would ask first.
mchd17
mchd17
- iatros
- Language Admin
Re: station.png
Hi mchd17
did you notice in the Main Template Settings : General Info ->Weather station icon ?
mchd17
Re: station.png
Tried again, it'll change the icon in the blocks that show station image, just not within the menu. Done this from day one of install.
mchd17
mchd17
- iatros
- Language Admin
Re: station.png
so where exactly would you have liked to change your station image?
- iatros
- Language Admin
Re: station.png
I see...
These are favicons from ../admin/menu/menuicons.php. I'm not sure whether you can change that without "hacking the code a bit", as you call it!
- Fraggboy
- Software: Bloomsky
Re: station.png
You have to create a new tab in order to change the big icon. You can't modify the icon once the tab has been created.
What I did was edit the current tab and copy the code (Paste it in notepad, etc). Delete that tab. Re-create the tab and follow the instructions on that page (I attached a screen shot). You can specify the smaller icon, and the larger icon.
Read, and read again, then experiment (I did)...
You can edit an existing tab, it is on the first page that lists the tabs, you can click Edit
mchd17
Re: station.png
Had to click EDIT on the Weatherstation tab, you can change tab namespace from there. Thanks.
mchd17
Re: station.png
even fixed the menu link icons within the tabs
text|link|icon
read read read the WIKI
text|link|icon
- iatros
- Language Admin
Re: station.png
The big icon in the weatherstation tab is defined in the setting I mentionned in my former post. I thought you meant the small icons beneath each item in a given menu tab!
<------ within the menu tabs
