mchd17
Post by mchd17 » Fri Apr 13, 2018 1:55 am
Anyway to change station.png to my station image (davispro2.png) within all the menu images? I guess I could hack the code a bit, thought I would ask first.
mchd17
iatros
Re: station.png
Post by iatros » Fri Apr 13, 2018 6:37 am
Hi mchd17
did you notice in the Main Template Settings : General Info ->Weather station icon ?
Language Admin für Deutsch
mchd17
Re: station.png
Post by mchd17 » Fri Apr 13, 2018 11:19 am
Yep, already did that, no change to menu station icon
mchd17
mchd17
Re: station.png
Post by mchd17 » Fri Apr 13, 2018 11:51 am
Tried again, it'll change the icon in the blocks that show station image, just not within the menu. Done this from day one of install.
mchd17
iatros
Re: station.png
Post by iatros » Fri Apr 13, 2018 4:18 pm
mchd17 wrote: Fri Apr 13, 2018 1:55 am within all the menu images
so where exactly would you have liked to change your station image?
mchd17
Re: station.png
Post by mchd17 » Fri Apr 13, 2018 5:04 pm
Image <------ within the menu tabs
Change that to the davispro2
iatros
Re: station.png
Post by iatros » Fri Apr 13, 2018 6:01 pm
I see...
These are favicons from ../admin/menu/menuicons.php. I'm not sure whether you can change that without "hacking the code a bit", as you call it!
mchd17
Re: station.png
Post by mchd17 » Fri Apr 13, 2018 6:08 pm
Fraggboy
Software: Bloomsky
Re: station.png
Post by Fraggboy » Fri Apr 13, 2018 8:40 pm
You have to create a new tab in order to change the big icon. You can't modify the icon once the tab has been created.
What I did was edit the current tab and copy the code (Paste it in notepad, etc). Delete that tab. Re-create the tab and follow the instructions on that page (I attached a screen shot). You can specify the smaller icon, and the larger icon.
Read, and read again, then experiment (I did)...
You can edit an existing tab, it is on the first page that lists the tabs, you can click Edit
mchd17
Re: station.png
Post by mchd17 » Fri Apr 13, 2018 10:53 pm
:lol: :lol: Got it.
Had to click EDIT on the Weatherstation tab, you can change tab namespace from there. Thanks.
mchd17
Re: station.png
Post by mchd17 » Fri Apr 13, 2018 11:11 pm
even fixed the menu link icons within the tabs ;)
text|link|icon
read read read the WIKI :lol: :P
iatros
Re: station.png
Post by iatros » Sat Apr 14, 2018 9:37 am
The big icon in the weatherstation tab is defined in the setting I mentionned in my former post. I thought you meant the small icons beneath each item in a given menu tab!
