INDOORDATA PLUGIN
Juan Maria Vilaro
INDOORDATA PLUGIN
Hello good afternoon, I have the latest version of Meteotemplate "http://www.meteobadalonaprogres.cat/template" working correctly, I use Weather Display with API, but I do not know why the Plugin "Indoordata" I can not configure it I tried it with the instructions that indicate in the Forum, but possibly for the translation to "Spanish" I do not interpret correctly the steps to follow, I would need help from some collaborator so that I can be guided in the correct configuration of the INDOORDATA plugin.
- Dehatter
- Station model: Ecowitt WH80
- Software: Ecowitt GW1000
Re: INDOORDATA PLUGIN
have you enabled the extra sensors data base?
Have you moved updateIndoor.php to the /load/crons/ folder?
Have you installed a cron job?
Not sure where you stand in the process, but all these things have to be done.
Juan Maria Vilaro
Thanks, you could tell me where and how the additional sensors are activated.
I do not know where to do it.
In Weather Display, I have the Meteotemplate CRON running to work with API.
The updateindoor.php file I have put in "Load / Crons / updateindoor.php"
Juan Maria Vilaro
Sorry, I have already been able to activate the extra sensors, but they still do not appear in the data.
See the plugin instructions, this plugin requires an additional cron job. It does not use the API directly - it could, it is technically possible, but the plugin was created before the API was introduced
Juan Maria Vilaro
Thanks Jachym, I do not quite understand this "TEMPLATE_ROOT / load / cron.php? Password = YOUR_UPDATE_PASSWORD"
Juan Maria Vilaro
Good afternoon, nothing, I have not managed to configure this plugin, possibly I am obfuscated, I do not know how to make the plugin work, I will appreciate that somebody can help me.
- Dehatter
First you need to know your update password. You created it in the main setup.
Next activate Extra sensors. From the Admin Control Panel:
then
Then move indoorUpdate.php to the folder ../load/crons/
then
- Dehatter
goto www.cron-job.org
Create an account.
Then create a cron job.
it should look like this:
The blacked out area is where your update pw goes. Use your template path, not mine.
[*]http://www.yourwebsite.com/template/loa ... urUpdatePW
It should be working now.
Create an account.
