I think this is how you asked for it.
https://drive.google.com/open?id=1otNPo ... 67imhyFprj
1. Do you have updateWebcam.php in the folder http://www.auestadhome.com/template/load/crons/ ?
2.If not locate it in the http://www.auestadhome.com/template/plugins/webcam/ folder and copy it to the crons folder above.
3.Download the file shared above and then copy it to the same http://www.auestadhome.com/template/load/crons/ folder.
4.I know you are running your cron job from MB but i HIGHLY HIGHLY recommend using https://cron-job.org/ . See directions/picture in a previous post. It is totally free and you don't have to figure anything out. Also its not dependent on your hardware AND a bonus, it off-loads work from your MB. It also emails you when it fails, which MB will not. You only need to have 1 cron job as MT will run ALL programs in the /crons/ folder. It will run the updates at your specified interval (1,2,5,10,15, or 30 minutes). I personally use 2 minutes for timing limitations (everything does not trigger exactly on time). My camera uploads every 1 minute. My MT updates every 10 minutes, but the block on the homepage will update every 2 minutes (using the same setup as I do).
5.Have the url http://auestadhome.com/template/webbilder/webcam2.jpg as the source for both block and plugin. You have to setup both the block and the plugin.
Everything SHOULD start to work.
I can help you with another way since you are using MB that will put the MB data on the bottom of the image....example...
