Steelseries Gauges don't work ?
Re: Steelseries Gauges don't work ?
Post by Dehatter » Mon Jan 14, 2019 9:44 pm
Great minds Andy!!
lol
Gatewayy
Software: Weathercat
Post by Gatewayy » Mon Jan 14, 2019 9:45 pm
I double checked the plugin and the clock and both show that the initial settings have been created.
Greenshot 2019-01-14 15.43.46.png (12.5 KiB) Viewed 30257 times
Post by Dehatter » Mon Jan 14, 2019 9:47 pm
did you actually create the gauges. In the plugin you pick your color and style options.
or did you just click save at the bottom?
Post by andyk1 » Mon Jan 14, 2019 9:49 pm
Hehehe I just noticed you changed the name of your site Tom and same url. :roll: :lol: :D
Post by andyk1 » Mon Jan 14, 2019 9:51 pm
Dehatter wrote: Mon Jan 14, 2019 9:47 pm Capture5.JPG
I think he's setting it up now Tom. No change yet.
Post by Dehatter » Mon Jan 14, 2019 9:52 pm
you can have a different set in the block.
Gatewayy
Post by Gatewayy » Mon Jan 14, 2019 9:54 pm
Yes I had changed a few of the settings so I just went back and changed a lot more of them but I am not seeing any changes yet.
Greenshot 2019-01-14 15.52.52.png (586.19 KiB) Viewed 30247 times
Post by andyk1 » Mon Jan 14, 2019 9:59 pm
Strange. Not sure whats up then. You don't have ssGauges listed twice do you?
Wait. Not sure you can use Gauges and ssGauses at the same time. Try as an experiment to only run one or the other.
Gatewayy
Post by Gatewayy » Mon Jan 14, 2019 10:01 pm
Good point, I removed the non SS block but I do not see a change.
Post by andyk1 » Mon Jan 14, 2019 10:04 pm
I see one of the gauges trying to load. Feels like/Dew Point but not showing the gauges. Something else is going on.
Post by andyk1 » Mon Jan 14, 2019 10:08 pm
The only thing I can think of at this point is delete and reinstall the ssGauges Block and steelSeries plugin and start over
Post by andyk1 » Mon Jan 14, 2019 10:13 pm
There is another Block Called Gauges. Not sure if that need to be set up. Look in blocks 'Gauges'
Post by Dehatter » Mon Jan 14, 2019 10:13 pm
One other thing.
he is not using the /template/ sub-directory. He has the template installed in the root.
Do you think something could be written to look in /template/ ?
I set the plugin up myself.
Post by andyk1 » Mon Jan 14, 2019 10:18 pm
If you look at my page I have both working I think the way you wanted? In my Desktop Homepage...header block I have"warningsUSRegions;ssGauges;gauges;nwsForecast" Try and see what happens?
Gatewayy
Post by Gatewayy » Mon Jan 14, 2019 10:19 pm
andyk1 wrote: Mon Jan 14, 2019 10:08 pm The only thing I can think of at this point is delete and reinstall the ssGauges Block and steelSeries plugin and start over
I removed both, re-downloaded the plugin and block and re-installed them, still looks to be the same.
Post by Dehatter » Mon Jan 14, 2019 10:19 pm
both run.
Post by andyk1 » Mon Jan 14, 2019 10:23 pm
Good point. But still it should point to /homepage/blocks/ssGauges and /plugins/steelSeries. I'm stumped. Has to be in a setting somewhere.
Post by Dehatter » Mon Jan 14, 2019 10:29 pm
me too. sigh
I checked all the phps, and there no reference instance of /template, but someone would have already checked that anyway.
Post by Dehatter » Mon Jan 14, 2019 10:30 pm
also hes using PHP ver 7,3
Can you step down to 7.2 or 7.1?
Post by andyk1 » Mon Jan 14, 2019 10:32 pm
I have both running on my site and can't find the cause why only one gauge 'Feels Like/Dew point try's to load in his ssGauges series.
Good point. About stepping down a version or two of PHP version.
Gatewayy
Post by Gatewayy » Mon Jan 14, 2019 10:33 pm
I just checked the scripts myself and yeah nothing looks like a hard coded path. I stepped PHP down to 7.1 to test.
Post by andyk1 » Mon Jan 14, 2019 10:38 pm
It has to be in the ssGauges block or steelSeries Plugin. It starts to load if you look at his panel the dew point and apparent sym... shows.
Post by Dehatter » Mon Jan 14, 2019 10:39 pm
Are you using the standard meteotemplatelive.txt for updates?
Gatewayy
Post by Gatewayy » Mon Jan 14, 2019 10:42 pm
Tht file does have values in it , I am sending from my station to the template via the api.php.
{"U":1547505626,"B":323,"W":4,"G":4,"H":91,"T":0.1,"HIN":61,"TIN":15.1,"RR":0,"R":0,"P":1027.2,"CO2_1":0,"SW":"WeatherCatV3.03B8","UTime":1547505626,"BTime":1547505626,"WTime":1547505626,"GTime":1547505626,"HTime":1547505626,"TTime":1547505626,"HINTime":1547505626,"TINTime":1547505626,"RRTime":1547505626,"RTime":1547505626,"PTime":1547505626,"CO2_1Time":1547505626,"SWTime":1547505626,"D":-1.2,"DTime":1547505626,"A":-2.8,"ATime":1547505626}
Post by Dehatter » Mon Jan 14, 2019 10:45 pm
ok so here a wierd thing.
On his plugin screen the guage summary icons load....and work......wierd!!!!
