Steelseries Gauges don't work ?
Gatewayy
- Station model: Netatmo
- Software: Weathercat
Re: Steelseries Gauges don't work ?
I double checked the plugin and the clock and both show that the initial settings have been created.
- Dehatter
- Station model: Ecowitt WH80
- Software: Ecowitt GW1000
did you actually create the gauges. In the plugin you pick your color and style options.
or did you just click save at the bottom?
- Station model: Ecowitt WS90
Hehehe I just noticed you changed the name of your site Tom and same url.
I think he's setting it up now Tom. No change yet.
Gatewayy
Yes I had changed a few of the settings so I just went back and changed a lot more of them but I am not seeing any changes yet.
Strange. Not sure whats up then. You don't have ssGauges listed twice do you?
Wait. Not sure you can use Gauges and ssGauses at the same time. Try as an experiment to only run one or the other.
Gatewayy
Good point, I removed the non SS block but I do not see a change.
I see one of the gauges trying to load. Feels like/Dew Point but not showing the gauges. Something else is going on.
The only thing I can think of at this point is delete and reinstall the ssGauges Block and steelSeries plugin and start over
There is another Block Called Gauges. Not sure if that need to be set up. Look in blocks 'Gauges'
- Dehatter
One other thing.
he is not using the /template/ sub-directory. He has the template installed in the root.
Do you think something could be written to look in /template/ ?
I set the plugin up myself.
If you look at my page I have both working I think the way you wanted? In my Desktop Homepage...header block I have"warningsUSRegions;ssGauges;gauges;nwsForecast" Try and see what happens?
Gatewayy
I removed both, re-downloaded the plugin and block and re-installed them, still looks to be the same.
Good point. But still it should point to /homepage/blocks/ssGauges and /plugins/steelSeries. I'm stumped. Has to be in a setting somewhere.
- Dehatter
me too. sigh
I checked all the phps, and there no reference instance of /template, but someone would have already checked that anyway.
I have both running on my site and can't find the cause why only one gauge 'Feels Like/Dew point try's to load in his ssGauges series.
Good point. About stepping down a version or two of PHP version.
Gatewayy
I just checked the scripts myself and yeah nothing looks like a hard coded path. I stepped PHP down to 7.1 to test.
It has to be in the ssGauges block or steelSeries Plugin. It starts to load if you look at his panel the dew point and apparent sym... shows.
Gatewayy
Tht file does have values in it , I am sending from my station to the template via the api.php.
{"U":1547505626,"B":323,"W":4,"G":4,"H":91,"T":0.1,"HIN":61,"TIN":15.1,"RR":0,"R":0,"P":1027.2,"CO2_1":0,"SW":"WeatherCatV3.03B8","UTime":1547505626,"BTime":1547505626,"WTime":1547505626,"GTime":1547505626,"HTime":1547505626,"TTime":1547505626,"HINTime":1547505626,"TINTime":1547505626,"RRTime":1547505626,"RTime":1547505626,"PTime":1547505626,"CO2_1Time":1547505626,"SWTime":1547505626,"D":-1.2,"DTime":1547505626,"A":-2.8,"ATime":1547505626}
- Dehatter
ok so here a wierd thing.
On his plugin screen the guage summary icons load....and work......wierd!!!!
