Extremely slow load
gand
Extremely slow load
Hi
Time to first byte is around 8 seconds, as seen on the screenshots, when indexDesktop.php is called. So what is going on in indexDesktop.php? The mobile page loads very fast.
Furthermore, I have 3-4 blocks which also load very slowly
Anyone who can come up with good ideas where to look?
Ubuntu 20.07
PHP 7.4
NGINX, no errors in the log
Gert
http://vsvejr.de
Ubuntu 20.07
PHP 7.4
Gert
http://vsvejr.de
- Untitled1.jpg (176.55 KiB) Viewed 11074 times
- Untitled.jpg (279.33 KiB) Viewed 11074 times
gand
Re: Extremely slow load
Hi
I have switched to Apache to see if it makes any difference. It seems not to be the case. I got this error now from the Apache log:
Got error 'PHP message: PHP Notice: Undefined index: saveLayout in /var/www/vsvejr.de/mt/admin/createHomepageWrite.php on line 17
PHP message: PHP Notice: file_get_contents(): read of 8192 bytes failed with errno=21 Is a directory in /var/www/vsvejr.de/mt/admin/createHomepageWrite.php
Any clues?
Rgds
Gert
Any clues?
Rgds
Gert
gand
Hi
Just an update.
When I'm at the main page with all the blocks, they are running very fast and I can switch back and forth between the blocks without any problems.
When I switch from the main page, to f.x Reports, I have this long wait time again. If I choose another function, I have the wait time again and also when returning to the main page.
Rgds
Gert
Just an update.
Rgds
Gert
- livejerseyweather
Hi there.
I too have had the same issue to the point I am now having to only use my mobile site so am not sure what is going on with the coding. Seems to only effect the desktop site. Www.jerseyweather.net
Sorry I couldn’t be of help
Ethan
Ethan
nineback
- Station model: Davis Pro2
- Software: WeeWX
I had a similar issue. The slow down was only effecting me and not others using the site. I found it happened if I was logged in to the template as admin. If I logged out as admin things returned to normal speed.
gand
Hi Ethan and Tom
Thanks for looking into this.
Tom, your site is fast, but you only have data from 2019 and 2020. I have data from 2015 and approx. 500,000 records in the database.
Ethan, your side is slow. You have data since 2005, so there are many records that need to be processed. (Apparently).
As a test, I created a database with only 1 year and the site was extremely fast. Then I put in data for 6 years and the site became slow. This was the default setup with no extra blocks and plugins.
It is probably only Jachym who can explain why the start-up takes a long time and what goes on in the code.
My conclusion is that there is probably nothing to do in the short term. In the longer term, you should probably look at the database design.
Furthermore I haven't found any way to optimize the database.
I am extremely pleased with Meteotemplate and really appreciate the great work Jachym has put into it.
Gert
Gert
nineback
- Software: WeeWX
Look at this site. It has data since 1 Jan 2016.
http://www.kq5s.com/template313/indexDesktop.php
- livejerseyweather
Weirdly I removed my web part that shows the database and it seemed to solve the issue.... for a while at least
I found another site that has more data than me but there site loads quickly https://weather.3dadams.com/indexDesktop.php
gand
Hi
Very weird, these sites loads quickly and the have a lot of data.
Which web part did you remove?
Gert
Gert
- livejerseyweather
The database ones eg station info and station history ones
