lightning block not showing map
kratochh
- Software: wl 2.0
Since some days the lightning block is not showing maps any more - is this a problem of my configuration or does anyone encouter the same issue?
- John B
Re: lightning block not showing map
No, kratochh, it is not your set up. It seems that Blitzortung has changed its file references/locations.
kratochh
- Software: wl 2.0
I just figured out what changes need to be done to work properly:
Just replace "images" with "www" in the link to the maps in the file "lightning_block.php"
https://www.blitzortung.org/Images/......
- John B
That is fantastic, kratochh, thank you ever so much.
For those who might have got confused trying to amend the lightningBlock.php file you can do the changes on the following lines:
106
147
154
160
166
172
178
184
190
196
203
On each of those lines you will find "http://images.blitzortung.org/Images ...". Simply change the word images to www thus:
http://www.blitzortung.org/Images...
Thanks again, kratochh, I am ever so pleased to have the block working again.
106
147
154
160
166
172
178
184
190
196
203
- lightningBlock.zip
- (1.97 KiB) Downloaded 493 times
