No picture on Facebook
tobydude
Software: Weatherdiaplay
Post by tobydude » Sat Jan 27, 2018 7:26 pm
Hi.
When I post the URL of my meteotemplate website on Facebook,
there is no image with the URL.
Any ideas why?
http://fjærvollan.no/template/indexDesktop.php
Re: No picture on Facebook
Post by Jachym » Sat Jan 27, 2018 7:34 pm
Try using the homepage (indexDesktop.php) rather than index. Facebook sometimes does unexpected things, but the homepage should work - it works for me
tobydude
Post by tobydude » Sat Jan 27, 2018 7:46 pm
Hi.
I use undextop.php (this: http://fjærvollan.no/template/indexDesktop.php )
but no picture. :/
Post by Jachym » Sat Jan 27, 2018 8:09 pm
The meta tag which sets this is there so it should be visible - unless they made some change in the facebook API
Post by Jachym » Sat Jan 27, 2018 8:15 pm
It should show imgs/logo.png, check if you have that file on your server
tobydude
Post by tobydude » Sat Jan 27, 2018 8:24 pm
Nope.
No logo.png in the imgs folder. :/
tobydude
Post by tobydude » Sat Jan 27, 2018 8:36 pm
the facebook share button in the footer, doesnt show an image either.
Post by Jachym » Sat Jan 27, 2018 8:37 pm
I think I know where the problem is. Thanks for letting me know, I wrote it down on my to-do list for v18 to fix this. I made one change in one previous version and didnt realize it broke this script.
tobydude
Post by tobydude » Sat Jan 27, 2018 8:47 pm
tobydude
Post by tobydude » Mon Feb 05, 2018 1:11 pm
Asked my ISP.
They said : Try facebook debugging.
Did´nt told me much.
mpca86
Station model: NodeMCU ESP8266
Software: via API
Post by mpca86 » Tue Feb 06, 2018 2:35 am
tobydude: in a similar sense I wrote here: viewtopic.php?f=55&t=1120
Now output from Facebook Sharing Debugger looks like this:
tobydude
Post by tobydude » Tue Feb 06, 2018 10:19 am
tobydude
Post by tobydude » Tue Feb 06, 2018 7:36 pm
Is there any place in the index.php I can fill in metatags?
The following will be treated as a redirect by the crawler:
A HTTP redirect
A <link rel="canonical" href=".." /> tag
A <meta property="og:url" content=".." /> tag
mpca86
Software: via API
Post by mpca86 » Thu Feb 08, 2018 6:41 pm
no index.php but header.php ;-)
tobydude
Post by tobydude » Fri Feb 09, 2018 7:31 am
More nag. :)
Where in heder.php?
At the top or bottom?.
This is the html tags I think should be put in:
"<html>
<head>
<meta http-equiv="refresh" content="0; url=template/index.php" />
<title>Meteotemplate</title>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<meta name="description" content="Meteotemplate - free website template for weather enthusiasts." />
<meta name="keywords" content="meteotemplate, fjærvoll weatherservice, fjærvoll weathersørvis, fjærvoll temperatur, fjærvoll vindstyrke, bø i vesterålen, fjærvoll værstasjon, værstasjon, weather nord-norge " />
<meta name="robots" content="index,follow" />
<link rel="icon" href="favicon.ico" type="image/x-icon">
</head>
</html>"
tobydude
Post by tobydude » Fri Feb 09, 2018 10:13 am
Seems I messed upp the whole webpage.
It went back to Meteotemplate 11.0 Passion Fruit
mpca86
Software: via API
Post by mpca86 » Fri Feb 09, 2018 9:45 pm
edited: OMG,, just read the code a little...
Post by Jachym » Fri Feb 09, 2018 9:50 pm
mpca86 wrote: Fri Feb 09, 2018 9:45 pm OMG,, just read the code a little...
For example, put it between lines 435 and 436....
MPCA86 - please stay polite, not everyone knows how to code
tobydude - keep in mind that unless you know exactly what you are doing things can go seriously wrong and what I always say is that everyone is free to modify the code, but at that moment Im no longer able to help them because making changes directly in the code means I no longer know what could be wrong
mpca86
Software: via API
Post by mpca86 » Fri Feb 09, 2018 10:10 pm
Jachym wrote: Fri Feb 09, 2018 9:50 pm
I have modified my post. I apologize and agree with your opinion!!
Post by Jachym » Fri Feb 09, 2018 10:18 pm
No problem, it was nothing serious, I just didnt want it to go further and thanks for helping tobydude
tobydude
Post by tobydude » Sat Feb 10, 2018 7:47 am
Thanks.
So, I can put a "html" kode in the middle of a .php-file?
Here:
Post by Jachym » Sat Feb 10, 2018 8:00 am
Im not sure what you are trying to achieve, Im afraid you will have to do it yourself, keep in mind that unless you really know PHP, HTML and CSS well it is a risky operation. Also keep in mind that making changes locks you out of updates because if you perform the update your changes will be reset, or you will not update which means you wont get any new functions released in upcoming versions
tobydude
Post by tobydude » Sat Feb 10, 2018 11:01 am
Ok. Thanks.
I´ll give it a rest. :)
MJW
Station model: AW WS-2000ish
Post by MJW » Tue Mar 06, 2018 1:24 am
I'm not sure if you ever solved this or not, but what I did was on line 1 of index.php added the following -
<meta property="og:image" content="http://westfamilynj.net/ObservatoryWestWeather.JPG" />, and then my preview image shows up.
Here is what Facebook debugger shows.
fb debugger.JPG (72.55 KiB) Viewed 26313 times
I have the manual changed documented in the Admin Notes section of my site.
Good luck!
So many trees in NJ!
tobydude
Post by tobydude » Tue Mar 06, 2018 6:52 pm
Thanks for the tip. I´ll try that.
