ridiculous amounts of decimals behind my comma?
- staccermaccer
- Station model: Davis pro plus II
- Software: WD, CUMULUS
Hi, all
Can someone tell me what's this when i take a look at my stationfeed?
08 Nov 2018 15:39:01 +0100","temperature":13.4000000000000003552713678800500929355621337890625,"relative_humidity":64,"pressure":1020.5,"wind_speed":1.899999999999999911182158029987476766109466552734375,"wind_gust":1.600000000000000088817841970012523233890533447265625,"apparent_temperature":12.300000000000000710542735760100185871124267578125,"dewpoint":6.70000000000000017763568394002504646778106689453125,"rain_rate":0,"bearing_degrees":129,"wind_direction":"SE","solar_radiation":33,"UV":0,"temperature_indoor":21.199999999999999289457264239899814128875732421875,"humidity_indoor":52,"sunshine_hours":4.4000000000000003552713678800500929355621337890625,
Staccermaccer,
Staccermaccer,
- staccermaccer
- Mauro
- Software: Meteohub
Re: ridiculous amounts of decimals behind my comma?
Hello Staccermaccer!
It seems that your data in xml format are ok
The json data are indeed a little problematic:
Can I suggest to change from json to xml format?
I don't know this particular plugin. So take my tip with the necessary benefit of the doubt.
Enjoy your day!
<?xml version="1.0"?>
<weather>
<station>
<name>Weather in Ekeren and Port of Antwerp</name>
<location>Antwerpen</location>
<latitude>51.2806</latitude>
<longitude>4.4208</longitude>
<model>Davis Pro2 Plus</model>
<software>WD</software>
</station>
<units>
<temperature_units>C</temperature_units>
<pressure_units>hPa</pressure_units>
<wind_speed_units>km/h</wind_speed_units>
<precipitation_units>mm</precipitation_units>
<solar_radiation_units>W/m2</solar_radiation_units>
</units>
<current_conditions>
<UNIX_timestamp>1541788141</UNIX_timestamp>
<local_time>09.11.2018 19.29</local_time>
<date_time>2018-11-09T19:29:01+01:00</date_time>
<rfc_time>Fri, 09 Nov 2018 19:29:01 +0100</rfc_time>
<temperature>10.1</temperature>
<relative_humidity>83.0</relative_humidity>
<pressure>1008.5</pressure>
<wind_speed>1.9</wind_speed>
<wind_gust>4.8</wind_gust>
<apparent_temperature>9.1</apparent_temperature>
<dewpoint>7.3</dewpoint>
<rain_rate>0.0</rain_rate>
<bearing_degrees>141</bearing_degrees>
<wind_direction>SE</wind_direction>
<solar_radiation>0</solar_radiation>
<UV>0.0</UV>
<temperature_indoor>21.4</temperature_indoor>
<humidity_indoor>53.0</humidity_indoor>
<sunshine_hours>2.3</sunshine_hours>
<leaf_wetness1>15</leaf_wetness1>
<temperature_sensor1>0.0</temperature_sensor1>
<soil_temperature1>0.0</soil_temperature1>
<temperature_sensor2>0.0</temperature_sensor2>
<humidity_sensor2>0.0</humidity_sensor2>
<soil_temperature2>0.0</soil_temperature2>
<temperature_sensor3>0.0</temperature_sensor3>
<humidity_sensor3>0.0</humidity_sensor3>
<soil_temperature3>0.0</soil_temperature3>
<leaf_wetness4>0</leaf_wetness4>
<temperature_sensor4>0.0</temperature_sensor4>
<humidity_sensor4>0.0</humidity_sensor4>
<soil_temperature4>0.0</soil_temperature4>
<temperature_sensor5>0.0</temperature_sensor5>
<humidity_sensor5>0.0</humidity_sensor5>
<temperature_sensor6>0.0</temperature_sensor6>
<humidity_sensor6>0.0</humidity_sensor6>
<temperature_sensor7>0.0</temperature_sensor7>
<humidity_sensor7>0.0</humidity_sensor7>
<temperature_sensor8>0.0</temperature_sensor8>
<humidity_sensor8>0.0</humidity_sensor8>
</current_conditions>
<today>
<date>2018-11-09</date>
<temperature_average>8.65</temperature_average>
<temperature_max>13.7</temperature_max>
<temperature_min>5.8</temperature_min>
<humidity_average>83.39</humidity_average>
<humidity_max>90.6</humidity_max>
<humidity_min>72.0</humidity_min>
<pressure_average>1013.00</pressure_average>
<pressure_max>1017.7</pressure_max>
<pressure_min>1008.5</pressure_min>
<dewpoint_average>5.92</dewpoint_average>
<dewpoint_max>8.7</dewpoint_max>
<dewpoint_min>3.9</dewpoint_min>
<apparent_temperature_average>7.46</apparent_temperature_average>
<apparent_temperature_max>12.8</apparent_temperature_max>
<apparent_temperature_min>4.4</apparent_temperature_min>
<wind_speed_average>1.43</wind_speed_average>
<wind_gust_max>18.5</wind_gust_max>
<precipitation>0.0</precipitation>
<rain_rate_max>0.0</rain_rate_max>
<solar_radiation_average>56</solar_radiation_average>
<solar_radiation_max>373</solar_radiation_max>
</today>
</weather>Code: Select all
{"station":{"name":"Weather in Ekeren and Port of Antwerp","location":"Antwerpen","latitude":51.28059999999999973852027324028313159942626953125,"longitude":4.4207999999999998408384271897375583648681640625,"model":"Davis Pro2 Plus","software":"WD"},"units":{"temperature_units":"C","pressure_units":"hPa","wind_speed_units":"km\/h","precipitation_units":"mm","solar_radiation_units":"W\/m2"},"current_conditions":{"UNIX_timestamp":1541788261,"local_time":"09.11.2018 19.31","date_time":"2018-11-09T19:31:01+01:00","rfc_time":"Fri, 09 Nov 2018 19:31:01 +0100","temperature":10.0999999999999996447286321199499070644378662109375,"relative_humidity":83,"pressure":1008.5,"wind_speed":1.899999999999999911182158029987476766109466552734375,"wind_gust":1.600000000000000088817841970012523233890533447265625,"apparent_temperature":9.0999999999999996447286321199499070644378662109375,"dewpoint":7.29999999999999982236431605997495353221893310546875,"rain_rate":0,"bearing_degrees":140,"wind_direction":"SE","solar_radiation":0,"UV":0,"temperature_indoor":21.39999999999999857891452847979962825775146484375,"humidity_indoor":52,"sunshine_hours":2.29999999999999982236431605997495353221893310546875,"leaf_wetness1":15,"temperature_sensor1":0,"soil_temperature1":0,"temperature_sensor2":0,"humidity_sensor2":0,"soil_temperature2":0,"temperature_sensor3":0,"humidity_sensor3":0,"soil_temperature3":0,"leaf_wetness4":0,"temperature_sensor4":0,"humidity_sensor4":0,"soil_temperature4":0,"temperature_sensor5":0,"humidity_sensor5":0,"temperature_sensor6":0,"humidity_sensor6":0,"temperature_sensor7":0,"humidity_sensor7":0,"temperature_sensor8":0,"humidity_sensor8":0},"today":{"date":"2018-11-09","temperature_average":8.6500000000000003552713678800500929355621337890625,"temperature_max":13.699999999999999289457264239899814128875732421875,"temperature_min":5.79999999999999982236431605997495353221893310546875,"humidity_average":83.3900000000000005684341886080801486968994140625,"humidity_max":90.599999999999994315658113919198513031005859375,"humidity_min":72,"pressure_average":1012.990000000000009094947017729282379150390625,"pressure_max":1017.700000000000045474735088646411895751953125,"pressure_min":1008.5,"dewpoint_average":5.92999999999999971578290569595992565155029296875,"dewpoint_max":8.699999999999999289457264239899814128875732421875,"dewpoint_min":3.899999999999999911182158029987476766109466552734375,"apparent_temperature_average":7.45999999999999996447286321199499070644378662109375,"apparent_temperature_max":12.800000000000000710542735760100185871124267578125,"apparent_temperature_min":4.4000000000000003552713678800500929355621337890625,"wind_speed_average":1.4299999999999999378275106209912337362766265869140625,"wind_gust_max":18.5,"precipitation":0,"rain_rate_max":0,"solar_radiation_average":56,"solar_radiation_max":373}}I don't know this particular plugin. So take my tip with the necessary benefit of the doubt.
Enjoy your day!
- staccermaccer
Thank you for your answer!
It's not alone in my json-file i am getting also ridicilous numbers on my site, see example in attachment...
Staccermaccer,
PS: Since a day or two i can't reach my Admin-pages too!
Staccermaccer,
- plot1.png (23.76 KiB) Viewed 13235 times
- Mauro
You're welcome Staccermaccer
Assuming that here a help from Jachym would be useful (I'm just a novice), the problem seems to be found further back in the data management flow.
You should take a look at the database to see if this abnormal data is also there.
In the positive case, the source of the data must be checked, since the cause of the problem would be necessary before the database itself (WU, meteohub, metehobridge, etc.).
Meanwhile, I believe that an analysis of the data contained in the database is the first step.
Enjoy your day!
Enjoy your day!
- staccermaccer
This is an excerpt of my database, seems to be OK or am i missing something…
Any suggestions of course welcome!
Staccermaccer,
Staccermaccer,
- database.png (59 KiB) Viewed 13216 times
- Mauro
Hi!
The database looks fine I guess.
It's necessary to go back an other step and check how the data are presented by the originator (WU, meteohub, meteobridge, etc.)
For example, an analysis of the clientraw.txt or other specific data files could be a good idea.
- staccermaccer
Example from clientraw:
12345 0.3 0.9 145 12.2 87 1001.0 4.3 8.1 79.6 0.038 10.000 20.7 60 0.0 2 0.0 0 0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0 0 0 15 28 07 Weather_in_Ekeren_and_Port_of_Antwerp-15:28:07 0 0 10 11 0 0 0 0 0 0 0 12.2 13.6 13.4 9.7 2 Rain -0.3 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 18.3 10.1 865.8 10/11/2018 14.8 9.9 13.4 8.3 0.0 3 3 5 4 2 3 3 3 3 1 12.7 12.7 12.6 12.6 12.5 12.4 12.4 12.3 12.3 12.3 2.5 2.5 2.5 2.8 3.0 3.0 3.0 4.1 4.1 4.3 13.4 9.7 12.2 10.1 0 --- --- 166 0 0 0.0 0.0 0 0 0 0 0 84.0 21.3 19.9 14.8 1005.4 999.9 18 07:55 07:55 11.8 7.9 10.4 7.6 1 2018 2018 -1 1 -1 192 169 183 186 178 159 182 176 181 140 15.0 255.0 2.1 11.1 51.0 -4.0 4.3 88 79 0 00:02 0 0 0 0 0 0 66.7 12:38 00:00 !!CWD_console_17.5!!
- Mauro
Use this parser to analyze your clientraw.txt file.
https://www.tnetweather.com/wdparserold/index.php
- staccermaccer
I think i have found the culprit, several months ago i switched from Cumulus software to Weather Display software. There was still a cronjob running to fetch parameters for Cumulus, i deleted that cronjob and now it seems to be working like it should be!
Thanks for all the help!
PS: still have one problem though, i can't login to my Admin pages..
Staccermaccer,
Staccermaccer,
- Mauro
Hi!
Great job!
Great job!
this most likely due to Javascript calculations. For some reasons of how it works, it sometimes makes these ridiculous numbers when converting units (doing some sort of calculation in general). It is very unpredictable, so far I wasnt able to find how to fix this, but there are many questions about it on the internet. I tried using the toFixed command in JS, but with no luck either.
- staccermaccer
Hi, Jachym
No probs, i still have some decimals here and there, but still can't get the CO2 block to work, any idea's on that perhaps?
Staccermaccer,
Staccermaccer,
