GFS
captainjackfan10
Station model: Acurite Atlas
GFS
Post by captainjackfan10 » Sat Jun 29, 2019 2:37 pm
I am not having any luck with the GFS Block the Meteo works great! Just not so much with the GFS. Think it may need a tune-up. :o
Douglas E. Cobb
Come Join My Facebook Weather Group! :D
:arrow: https://www.facebook.com/groups/6008536 ... =bookmarks
Pavel
Station model: TFA 35.1075 NEXUS
Re: GFS
Post by Pavel » Mon Jul 08, 2019 6:40 am
Hi, GFS has some problems, does not show the map, the meteogram is probably rain as a sum of rainfall, others works GFS block normally, or is it just a mistake?
captainjackfan10
Re: GFS
Post by captainjackfan10 » Thu Jul 11, 2019 8:29 pm
Working Great Now! Thanks! The Problem Was Corrected! :D
Douglas E. Cobb
Pavel
Re: GFS
Post by Pavel » Tue Jul 16, 2019 8:33 am
Hi, GFS doesn't work for me. It only shows the amount of rain that is constantly growing
and the map is not showing
kd7eir
Station model: Ecowitt Wittboy
Software: FOSHKplugin
Re: GFS
Post by kd7eir » Thu Aug 01, 2019 7:51 pm
I deleted the gfs folder, downloaded the gfs block again, uploaded the gfs block, and it's now working fine for me.
Pavel
Re: GFS
Post by Pavel » Fri Aug 02, 2019 12:44 pm
hello, your progress does not help when I look at your site, I see the same problem, the map is not displayed and the meteogram is not seeing individual precipitation, but the summary
nicoloconte
Station model: WS1001
Re: GFS
Post by nicoloconte » Tue Oct 15, 2019 12:24 pm
Pavel wrote: Fri Aug 02, 2019 12:44 pm hello, your progress does not help when I look at your site, I see the same problem, the map is not displayed and the meteogram is not seeing individual precipitation, but the summary
Same problem for me, any solution?
Meteopomezia
Software: Wview
Re: GFS
Post by Meteopomezia » Fri May 08, 2020 3:58 pm
Hello everyone
I have been noticing for a few days that the GFS block no longer works on what it can depend on :?
al60
Station model: Vantage Pro 2
Re: GFS
Post by al60 » Tue May 12, 2020 2:34 pm
Meteopomezia wrote: Fri May 08, 2020 3:58 pm Hello everyone
I have the same problem, the GFS block no longer displays anything.
Do you have an idea to solve this problem?
cordially
(Google translate)
didoujm
Software: WEATHER DISPLAY
Re: GFS
Post by didoujm » Tue May 12, 2020 7:27 pm
le programme fonctionne avec le site http://wxcharts.eu/php/get_gfs.php?days=10&lat ça fonctionne plus l'adresse wxcharts.eu Ce site est inaccessible Impossible de trouver l'adresse IP du serveur de wxcharts.eu.
Essayez d'exécuter les diagnostics réseau de Windows.
DNS_PROBE_FINISHED_NXDOMAIN.
Par contre le site https://www.wxcharts.com/ fonctionne correctement
al60
Re: GFS
Post by al60 » Wed May 13, 2020 8:47 am
the site http://www.wxcharts.eu/ no longer works it has been removed. The https://wxcharts.com site works well.
http://www.wxcharts.eu must be replaced by https://wxcharts.com in the gfsBlock.php files and in gfsBlockTable.php using note ++ using the replace function.
Jachym, if you read us, can you update the gfs block. Thank you
Have a good day
(google translate)
Jolumarali
Station model: Vantage Vue
Software: WlIP
Re: GFS
Post by Jolumarali » Wed May 13, 2020 9:58 am
Perfect everything works
thank you
Merci
Meteopomezia
Software: Wview
Re: GFS
Post by Meteopomezia » Fri May 15, 2020 6:42 pm
Hello to all friends solved the gfs block now displays the map and the link removed eu and put .com
now the maps are visible almost all, in some countries some cards may not work, for italy they all work.
it will be very difficult to correct because the GFS number changes,
I hope to solve this too.
For the moment, enjoy these changes.
I'm italian sorry school english.
greetings: D: D: D
The only problem is that the WXcharts site creates images only on request
for example if you click on wind speed then you will also see it on the gif block.
I hope to solve ...
gfs.zip
Vers. 2.0
(10.61 KiB) Downloaded 985 times
Lespius
Station model: Davis VP2
Re: GFS
Post by Lespius » Sun May 17, 2020 5:30 pm
al60 wrote: Wed May 13, 2020 8:47 am the site http://www.wxcharts.eu/ no longer works it has been removed. The https://wxcharts.com site works well.
Have a good day
(google translate)
J'ai remplacé l'adresse de wxcharts mais ça ne marche pas. Ni graphs ni carte. Je vois que chez toi il te manque la carte aussi.
al60
Re: GFS
Post by al60 » Mon May 18, 2020 4:49 am
[/quote]
[/quote]
J'ai signalé le problème à Jachym, je pense qu'une mise à jour va pas tarder à arriver. Pour ce qui est des cartes, Meteopomezia essai de résoudre le problème.
Jolumarali
Software: WlIP
Re: GFS
Post by Jolumarali » Mon May 18, 2020 5:50 am
Bonjour
Version Meteopomezia, fonctionne parfaitement chez moi. (map idem)
Traduction Infos en français
Voir sur mon sous-menu graphique interactif
Ci joint mon block
Portez-vous bien
gfs.7z
(13.44 KiB) Downloaded 808 times
Pavel
Re: GFS
Post by Pavel » Mon May 18, 2020 8:15 am
Thanks for fixing GFS, but I'm not satisfied yet, it still shows a summary of the rain, but not individual precipitation, as it was in the past, see the picture. Could it still be fixed? Thank you very much.
al60
Re: GFS
Post by al60 » Mon May 18, 2020 3:35 pm
Jolumarali wrote: Mon May 18, 2020 5:50 am Bonjour
Ci joint mon block
Portez-vous bien
Merci beaucoup, celà fonctionne trés bien graphiques et carte.
Lespius
Re: GFS
Post by Lespius » Sat May 23, 2020 1:46 pm
al60 wrote: Mon May 18, 2020 3:35 pm
Ci joint mon block
Portez-vous bien
Oui, tout fonctionne, merci !
