Can anyone help with the myForecast block, I've set it up, added my forecast but the icons don't appear on the weather page. www.dullstroomweather.co.za/template/indexDesktop.php
Thanks.
Charl.
myForecast block
myForecast block
- myF3.jpg (26.31 KiB) Viewed 6761 times
- myF2.jpg (84.44 KiB) Viewed 6761 times
- myF1.jpg (47.56 KiB) Viewed 6761 times
Re: myForecast block
Finally sorted this problem out, I was filling out the forecast using Microsoft Edge and not Google and that is why the icon was not appearing on the webpage.
ph2
That didn't change anything for me, no matter which browser I used. In my opinion, the problem is in the file myForecastBlock.php: Here an if-query is used to search for a file settings.php. If this is not found, then "else" is run through and the script is terminated with the command "die" and there is no second query for settings2.php. For me there isno settings.php, only settings2.php. I changed the first “if” to settings2.php, now it works. Jachym, I think that should be changed in the download files!
