Solar radiation wrong
Avery
Software: Meteotemplate
Post by Avery » Thu Jul 22, 2021 6:05 am
Hello everyone!
I have a problem with the display of solar radiation.
The instrument always shows too little. I included a picture.
12 w/m2 are displayed, but in reality it is 120 w/m2.
How can I change this?
Re: Solar radiation wrong
Post by davidefa » Thu Jul 22, 2021 8:07 am
- only the gauge block shows incorrect values?
- is the shown value always 10% of the correct value?
- how do you 'send data' to your meteotemplate database?
- if your 'uploading software' calls api.php directly and has a log of the calls to api.php check this log ( or enable it )
- check your cache/apiLog.txt ( is generated by the api.php script and contains a lot of informations on the 'data import' phase )
P.S. Please provide a link to your meteotemplate site
Avery
Post by Avery » Thu Jul 22, 2021 10:49 am
No, all values are displayed incorrectly.
Yes.
I use the Meteohub plugin to get the data.
There is no log.
Post by davidefa » Thu Jul 22, 2021 1:27 pm
- is the content of the file clientraw.txt correct?
- please provide a link to your meteotemplate site
Post by davidefa » Fri Jul 23, 2021 7:20 am
Ok I found your meteotemplate site, but can't find your clientraw.txt.
Please attach one ( recorded during the day ) annotating the correct value of the solar sensor in that moment. I can check what's going wrong with the solar sensor
Avery
Post by Avery » Mon Jul 26, 2021 9:39 am
Here is the link to the Meteotemplate of the Elversberg station:https://wetterbase.de/Daten/meteotempla ... esktop.php
Image Awekas: Image
Image Meteotemplate: Image
clientraw.txt
12345 0.0 0.0 36 20.2 87 1009.2 0.00 0.00 0.00 0.00 0.00 21.7 63 - 19 - - 0 0.00 - - - - - - - - - 11 26 01 Elversberg-11:26 0 93 26 07 - - - - - - - 20.2 26.2 20.1 15.1 19 Zunehmend_bewölkt_mit_geringer_Temperaturänderung. 0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.4 0.0 0.0 0.4 0.0 0.7 3.5 18.0 880 26/07/2021 26.4 18.8 20.1 15.1 4.2 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 18.6 17.6 15.7 15.1 15.2 15.5 15.8 16.0 16.3 16.6 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 20.1 15.1 20.2 0.0 0 _ _ 292.5 _ 0 - - - - - - - 856.0 22.1 21.4 - 1009.5 1007.2 0.8 10:34 09:49 - - 18.4 14.4 0.0 2021 _ 1 0 1 338 45 0 0 0 0 293 293 293 315 - - 0.0 - 49.316389 -7.12 - 97.0 88.0 - 06:38 !!C10.37Of!!
Post by davidefa » Mon Jul 26, 2021 11:42 am
Your clientraw.txt in field 34 ( solar radiation field ) contains 93 and this is reported by meteotemplate.
So your clientraw.txt contains an incorrect solar radiation value.
P.S. Cant read the images you attached
Avery
Post by Avery » Mon Jul 26, 2021 4:28 pm
Okay, so parameter 34 is displayed correctly.
I think I found the problem.
Actually, the instrument should display the value of parameter 127. How can I change that from 34 to 127?
Post by davidefa » Mon Jul 26, 2021 5:07 pm
Install this version of the meteohub plugin, it should fix it.
Rerun the setup of the plugin:
- added a 'Solar Sensor Field Number' ( that you should set to 127 )
meteohub_2.1.zip
(3.27 KiB) Downloaded 431 times
Avery
Post by Avery » Mon Jul 26, 2021 5:23 pm
Thank you for the excellent support. I installed the plugin and it works perfectly.
Thanks very much!
