The formula in the block isn't correct, there's some part missing it should be more like this:
Convert Tdry from ºF to ºC: tdry = (ºF-32)·5/9
Convert RH% from percent to decimal value: rh = (RH%/100%)
Calculate dry-bulb vapor pressure: e(dry) = 6.112*EXP[17.62·tdry/(243.12+tdry)]
Approximate wet-bulb vapor pressure, e(wet), as square-root of rh times e(dry): e(wet) ≈ e(dry)·√(rh)
Calculate approximate wet-bulb temperature, twet, from approximated wet-bulb vapor pressure: twet ≈ (237.7×Log[e(wet)/6.108])/(7.5 - Log[e(wet)/6.108])
Convert twet from ºC to ºF: Tdry = 1.8*ºC+32
https://cr4.globalspec.com/thread/60813 ... -Bulb-Temp
when I do this with my current conditions I find 2.4C
When I do the artan formula I find 4.4C
My weatherlink says : 1.7C
I edited my updater.php to the arctan formula, already much better.
But I don't know how to php the above more correct formula.
PS: wet bulb can never be above the outside temp otherwise we humans could not cool ourselves.
ok for the heatindex and the windchill, although I would like to see it always
I attached some screenshots before adjust updater, and after , and a aplication note from davis instruments about their calculated measurements.
cheers
Alex
- after.PNG (70.5 KiB) Viewed 11438 times
- before.PNG (56.3 KiB) Viewed 11438 times
https://support.davisinstruments.com/ar ... r-products
