current conditions block wet bulb temp
Posted: Thu Mar 03, 2022 3:53 pm
by alexvanuxem
A question about the wet bulb reading in the current conditions block (detail view):
the wet bulb temp seems to be always above the actual outside tempearture.
I think that's not correct
, it should be way less.
Also the windchill tempearture isn't always showing: maybe it's calculated only every 10 minutes????
the heatindex is never showing.
I transfer data through my meteobridge coming from my weatherlink live davis station, maybe the settings there aren't correct?
Re: current conditions block wet bulb temp
Posted: Thu Mar 03, 2022 9:00 pm
Wind chill is calculated only for T<=10°C and W>4.8km/h
Heat index is calculated only for T>=26.7°C (corrected, I had previously written the opposite )
This is the function calculating wet-bulb:
// Wet-bulb - https://en.wikipedia.org/wiki/Wet-bulb_temperature
function getWB($WB_T,$WB_H){
global $displayTempUnits;
$e = $WB_H / 100 * 6.105 * exp(17.27 * $WB_T / (237.7 + $WB_T));
$WB = 0.567 * $WB_T + 0.393 * $e + 3.94;
$WB = convertor($WB,"C",$displayTempUnits);
return number_format($WB,1,".","");
Another widespread formula is this ( don't know the precision of the formula ):
Tw = T * arctan[0.151977 * (rh% + 8.313659)^(1/2)] + arctan(T + rh%) - arctan(rh% - 1.676331) + 0.00391838 *(rh%)^(3/2) * arctan(0.023101 * rh%) - 4.686035
$Tw = $T * atan(0.151977 * pow($H + 8.313659,1/2)) + atan($T + $H) - atan($H - 1.676331) + 0.00391838 * pow($H,3/2) * atan(0.023101 * $H) - 4.686035;
Posted: Fri Mar 04, 2022 5:39 pm
by alexvanuxem
The formula in the block isn't correct, there's some part missing it should be more like this:
Convert Tdry from ºF to ºC: tdry = (ºF-32)·5/9
Convert RH% from percent to decimal value: rh = (RH%/100%)
Calculate dry-bulb vapor pressure: e(dry) = 6.112*EXP[17.62·tdry/(243.12+tdry)]
Approximate wet-bulb vapor pressure, e(wet), as square-root of rh times e(dry): e(wet) ≈ e(dry)·√(rh)
Calculate approximate wet-bulb temperature, twet, from approximated wet-bulb vapor pressure: twet ≈ (237.7×Log[e(wet)/6.108])/(7.5 - Log[e(wet)/6.108])
Convert twet from ºC to ºF: Tdry = 1.8*ºC+32
https://cr4.globalspec.com/thread/60813 ... -Bulb-Temp
when I do this with my current conditions I find 2.4C
When I do the artan formula I find 4.4C
My weatherlink says : 1.7C
I edited my updater.php to the arctan formula, already much better.
But I don't know how to php the above more correct formula.
PS: wet bulb can never be above the outside temp otherwise we humans could not cool ourselves.
ok for the heatindex and the windchill, although I would like to see it always
I attached some screenshots before adjust updater, and after , and a aplication note from davis instruments about their calculated measurements.
cheers
Alex
- after.PNG (70.5 KiB) Viewed 11441 times
- before.PNG (56.3 KiB) Viewed 11441 times
https://support.davisinstruments.com/ar ... r-products
Posted: Sat Mar 05, 2022 9:01 pm
ver 24.4
- added approximate formula for wet bulb temperature calculation ( Roland Stull
https://journals.ametsoc.org/view/journ ... xt-display ) error +/-0.65°C according to authors evaluation ( calculated at 1013hPa )
- added accurate ( and iterative ) formula for wet bulb temperature calculation ( Roland Stull
https://www.eoas.ubc.ca/books/Practical ... kColor.pdf ) error +/-0.1°C ( personal evaluation ) and corrected for absolute local pressure ( disabled by default )
Posted: Sat Mar 05, 2022 9:07 pm
I have tried to convert the Davis formula but there is something I did wrong:
here the formula in php sandbox
Posted: Sat Mar 05, 2022 10:14 pm
by alexvanuxem
THANK YOU MAN!
You are my hero!
Posted: Mon Mar 07, 2022 7:53 pm
by alexvanuxem
I chedked yr calculations in the sandbox php
the only 'fault' I couild find is the calculaction of es
es = 6.112 * exp [(17.62*TC)/(TC + 243.12)] (also used in our dewpoint calculation) (my remark: probably in Kelvin
= davis explanation)
you wrote in your sandbox php
$es = 0.6113 * exp((17.2694 * $T)/($Tk - 35.86));
Could it possibly mean that '26' means '62'
If I was possibly wrong, please accept my excuses, I'm only learning.
PS: in your accurate wetbulb calc, how should I determine my offset of pressure?
PS: can you advise a free php program? without a free trial? and if posibly a 'web' learning cource about php?
PS: Thank you.
Grace milo.
Posted: Wed Mar 09, 2022 5:21 pm
by Meteofabro
Hi Davidefa.
The item "Relative Pressure Offset (in hPa, used in the accurate calculation of the wet bulb temperature)" which must contain precisely. How do I know what offset to put !.
Posted: Wed Mar 09, 2022 5:49 pm
The 'absolute to relative offset' is the same offset to convert your weather station absolute to relative pressure .
If you don't have to input it in your weather station/weather software you can calculate it with the
keisan calculator ( or something like that )
The offset is the difference between the sea level pressure and the absolute pressure ( a positive number )
- pofs.png (164.89 KiB) Viewed 11339 times
Posted: Wed Mar 09, 2022 5:56 pm
@alexvanuxem
You can use, for example,
xampp which include an http server, a mysql server, php... you can install for example a local copy of meteotemplate and run it locally ( I do it for testing purposes ).
I use the
portable version and start it manually.
P.S. For a php course don't know what to recommend..
Posted: Wed Mar 09, 2022 8:18 pm
by alexvanuxem
thx,
i tried your sandbox php again, with the values I see on my weatherlink live.
the first Tw value seems to match the value on the weather link live app.
so I don't know where you think you have gone wrong.
the davis calculation seems to be correct.
Now the discussion starts which calculation is the moste correct. interesting stuff.
Thanks again, learning day per day.
Posted: Wed Mar 09, 2022 10:13 pm
by Meteofabro
davidefa wrote: ↑Wed Mar 09, 2022 5:49 pm
