How to edit rain data block
i_fiorentino
Post by i_fiorentino » Sun Aug 28, 2022 9:08 am
Hi to all,
is it possible to edit rain data on rain block?
If yes, how to?
Thanks in advance.
Alessandro
Re: How to edit rain data block
Post by davidefa » Sun Aug 28, 2022 2:41 pm
Not sure to understand your question, but values shown in the rain block are calculated from the records stored in the database.
So altering the database you can modify these values ( for example using the database -> edit data from the meteotemplate control panel, but it could be a quite long task ).
What are you trying to do?
i_fiorentino
Post by i_fiorentino » Sun Aug 28, 2022 6:48 pm
Hi Davide,
thanks for reply.
I would edit month (and year) rain because that data is wrong.
It shown much more rain than real because a bird (tortora) nested on main rain gauge all summer :lol:
I've tried to edit last line of db but without success.
Would i use phpmyadmin?
Alessandro
Post by davidefa » Mon Aug 29, 2022 1:09 pm
In these cases phpmyadmin is your friend.
You may try something like this ( substitute the appropriate starting and ending dates ):
UPDATE alldata SET RR=0,R=0 WHERE DateTime >= '2022-08-08 00:00:00' AND DateTime <= '2022-08-08 23:55:00'
It is always a good idea to make a backup copy of the database
You may also try the 'Simulate query' button ( before the 'Go button ) to verify that results are reasonable (i.e. you should have roughly 288 results/day )
