Where and how do I update the MENU for mobile?
Julius
Software: meteobridge
Post by Julius » Sat Sep 03, 2022 2:49 pm
It's not in the Wiki, it's nowhere to be found, and the mobile devices still see the oldest default menu I had.
Must be missing something really obvious, but I can't find it..
Julius
Re: Where and how do I update the MENU for mobile?
Post by Julius » Sun Sep 11, 2022 2:28 pm
Really? Nobody else ever encountered this? The menu for indexMobile is always the same old one. It does not change..
Post by alexvanuxem » Sun Sep 11, 2022 4:03 pm
go to your control panel.
In homepage: you can setup your desktop or youir mibile version, :-)
gwatuk
Station model: EcoWitt
Post by gwatuk » Sun Sep 25, 2022 1:46 pm
I'm very new here.
I have the same problem.
"go to your control panel.
In homepage: you can setup your desktop or youir mibile version"
I can't see any reference to menu in the homepage area.
Post by davidefa » Tue Sep 27, 2022 11:34 am
Not sure to understand correctly the question:
- are you referring to the menu 'look' ( in mobile/desktop version )
- or to the 'menu content' ( in mobile/desktop version )
I think the menu content is fixed in both versions, the look is a little bit different but I think both can be changed.
Desktop in desktop browser
mobile in desktop browser
mobile in mobile browser
gwatuk
Post by gwatuk » Tue Sep 27, 2022 12:48 pm
Thanks fo your reply @davidefa
I've added a new tab to the menu which is a link to another site.
So instead of 5 tabs (WEATHER STATION....INFO) I now have 6.
There are now 6 tabs visible on the desktop version, but only the default 5 on the mobile version.
Post by davidefa » Wed Sep 28, 2022 5:00 pm
Ok, I will take a look
Sarah R Taylor
Software: I hope to use a Meteo-Pi
Post by Sarah R Taylor » Fri Nov 18, 2022 1:05 am
I am having the same problem (I think). I now have a windDirection plugin available on my Desktop menu (the line of text across the top like: Weather Station Weather Climate Astronomy Info) which are pull-down lists where you can select a choice. I was successful in adding the windDirection plugin there. But when I try to add this to the Mobile menu using the Menu Setup choice in the Admin menu, I only get the menu applicable to the Desktop.
I tried invoking the Menu Setup from within the Mobile view but I only get to adjust the Desktop version.
My station is at: www.owlsheadns.com/template/
Sarah R Taylor
Re: Where and how do I update the MENU for mobile? Solved??
Post by Sarah R Taylor » Fri Nov 18, 2022 1:32 am
I may have figured out a work-around, at least for a plugin.
I edited the php file /template/mobile/menu.php.
I copied line 477
<li><a href='<?php echo $pageURL.$path?>mobile/pages/forecast/index.php'><?php echo lang("outlook",'c')?></a></li>
and pasted it as line 478.
Then on the new line 478 I edited the =>mobile/pages/forecast/index.php<= to say =>plugins/windDirection/index.php<= (don't use => and <=)
This seems to work on my personal computer viewing a mobile version, and also on my Samsung Galaxy Tab A7.
Julius
Post by Julius » Fri Apr 28, 2023 12:16 pm
I still have only some weird un-configurable default menu in mobile, no matter how often I edit it in the admin screens.
Is meteotemplate still being maintained?
Julius
Post by Julius » Fri Apr 28, 2023 2:27 pm
alexvanuxem wrote: Sun Sep 11, 2022 4:03 pm go to your control panel.
No you can't. Under /admin/menu/menuTabs.php I see no distinction between mobile or desktop. And the mobile menu is not what I've made it here.
Post by FSC830 » Sat Apr 29, 2023 8:30 am
Julius wrote: Fri Apr 28, 2023 2:27 pm
May you better give more details what is going wrong at your site.
At my sites (real online and VMs) I can edit/modify the mobile homepage as described by @alexvanuxem.
So my guess its an individual issue at your site.
Julius
Post by Julius » Fri May 05, 2023 10:24 pm
FSC830 wrote: Sat Apr 29, 2023 8:30 am.
I can edit the mobile homepage fine, but not the menu. And from the looks of your site, you also can't edit it, because it shows the default. Worse yet, your site looks like shit on mobile.
Post by FSC830 » Sat May 06, 2023 6:31 am
Julius wrote: Fri May 05, 2023 10:24 pm ... And from the looks of your site, you also can't edit it, because it shows the default. Worse yet, your site looks like shit on mobile.
Always a pleasure to read such polite posts.
And always a good motivation for helping in such issues. :!:
Jolumarali
Station model: Vantage Vue
Software: WlIP
Post by Jolumarali » Sat May 06, 2023 6:44 am
Hello Gruss :)
for the mobile page, personally, I put a single column.
see link below to view result on mobile
https://meteo-lignerolles.fr/indexMobile.php
Have a good day.
Jose Luis
Julius
Post by Julius » Mon May 08, 2023 8:42 pm
FSC830 wrote: Sat May 06, 2023 6:31 am Always a pleasure to read such polite posts.
How is that impolite? Should I just ignore how it looks? I'm not stating that YOU build shit websites, just that on mobile it fails, just like mine by the way. My MT site also currently looks like crap on mobile, but since we have to wait for its designer to work on that I want to wait before working much on that part of it.
