Riset block disappeared
i_fiorentino
Post by i_fiorentino » Sun Dec 04, 2022 5:44 pm
Hi guys,
i've another issue with riset block.
It disappeared from home in the right column: https://meteofirenze.eu
I've also installed new ver. 7.0 but without lucky.
Any ideas?
Thanks again,
Alessandro
Re: Riset block disappeared
Post by davidefa » Tue Dec 06, 2022 11:01 pm
The error returned by the block is the following:
You need the 'calendar' extension installed in php ( see my phpinfo with calendar enabled ):
This extension is supported since php 4.
Maybe you switched php version?
Check in your provider control panel if there is an option to enable it
