davisWLL
davisWLL
Post by alexvanuxem » Mon Aug 28, 2023 5:09 pm
does somebody use the davisWLL plugin?
it would be nice to php this to 8.2...
thx
Re: davisWLL
Post by davidefa » Sun Oct 08, 2023 4:01 pm
It should be already php8.2 compatible, I can see it is working on your site ( the highlighted items are those configured to be imported by davisWLL plugin )
Re: davisWLL
Post by alexvanuxem » Mon Oct 09, 2023 3:50 pm
Hi David ,
long time no hear,
this is strange because at that moment there was no cron job updatWLL.php in place.
I put the updateWLL.php back in place, run it manually and I still get a 500 error. See picture.
thank you for your time!
Schermafbeelding 2023-10-09 174827.png (82.65 KiB) Viewed 27449 times
Re: davisWLL
Post by alexvanuxem » Mon Oct 09, 2023 4:33 pm
HI David
i isololated the issue, the cron.php can't handle multiple cron requests
It's either updateWLL or updateEcowittNet.php
both gives a 500 error.
Re: davisWLL
Post by davidefa » Mon Oct 09, 2023 6:40 pm
Thanks for checking ( and reporting ).
Can't understand why this happen, but maybe it has something to do with the fact that both scripts are calling api.php.
Need to dig further.
Re: davisWLL
Post by alexvanuxem » Tue Oct 10, 2023 6:51 am
thx man!,
I was thinking to undouble the cron jobs, e.g. make two of them.
would that bypass the issue, probably set at different times, although at some point they will occur together?
are there any cron rules i could apply so they never run together?
cheers
Re: davisWLL
Post by alexvanuxem » Tue Oct 10, 2023 3:34 pm
doesnt work apperently... :-(
