Live Gauges API
- stadelhofen
- Station model: Davis Vintage Pro 2
Live Gauges API
Hi everybody
How is it possible to display the Live Gauges API in the homepage instead of a menu.
Since «gauges» is displayd in the list of blocks/plugins, I assume, that it should be possible to add it as a block?
Many thanks for any support.
Michael
Michael
Re: Live Gauges API
There are two blocks:
- gauges
- steelSeries
- gauges
- steelSeries
- stadelhofen
Re: Live Gauges API
yes, but if I set gauges, the homepage is empty
- Bildschirmfoto 2017-10-05 um 11.27.59.png (478.72 KiB) Viewed 24462 times
- nikokara - BANNED
- Station model: ng265 (Fine Offset)
Re: Live Gauges API
Desktop homepage --> Header block
and input
current;ssGauges
(separaded by semicolon)
klick Save
and input
current;ssGauges
klick Save
niko
Re: Live Gauges API
I cannot view your website, looks like a security problem, Chrome blocks it
- stadelhofen
Re: Live Gauges API
I woud like to use the Live Gauges.
I tried this: current;gauges in the Headerblock, but with no success.
- nikokara - BANNED
- stadelhofen
Re: Live Gauges API
yes, I replaced it, but I don't understand, why I can't place current;gauges in the homepage
Re: Live Gauges API
I cannot check this because when I try to go to your website, Chrome gives me a security warning and does not let me view it.
- stadelhofen
Re: Live Gauges API
can you use another browser instead?
That was the reason, ehy I first tried it to host it with SSL and you responded, that this is not implemented in your Template
Re: Live Gauges API
not sure what you mean, https/http has nothing to do with the actual scripts, it is not something I need to change in the template. You can use any PHP script on any https server.
HTTP/HTTPS is purely a server/domain settings, regardless of what you then use on that server. The only thing that can sometimes happen is that some data might not be loaded if it is http (especially images), but it happens very rarely.
I think you should first fix this because if your web is inaccessible from the most widely used browser it is a serious issue
- stadelhofen
Re: Live Gauges API
I asked the Provider to install Lets Encrypt for this domain: http://meteo.ksstadelhofen.ch/template/indexDesktop.php
I need your support, because I do not understand the Plugin description for the gauges.
When I write current;gauges in the header Block, or further down in the Column1 and save it, I can't see any gauges
- Bildschirmfoto 2017-10-05 um 17.44.28.png (12.65 KiB) Viewed 24413 times
- stadelhofen
Re: Live Gauges API
and when do you implement SSL for http://www.meteotemplate.com ?
you wrote: I think you should first fix this because if your web is inaccessible from the most widely used browser it is a serious issue...
- Johnny
- Developer
Re: Live Gauges API
Hi, the link in your profile shows this:
https://meteokst.lima-city.de/template/ ... veData.php
If you go to that link you are warned of a site problem and advised not to go further.
If you go to the link you have just posted:
It works, so which is the correct link for your MT site? Or is it both?
- stadelhofen
Re: Live Gauges API
it's http://meteo.ksstadelhofen.ch
I changed it in my profile
But my question remains the same, how can I implement gauges in the homepage?
- jay_hoehn
- Language Admin
- Software: WeeWx
Re: Live Gauges API
Have you tried redownloading the block and reuploading it to the server?
Jay
Jay
- Johnny
- Developer
Re: Live Gauges API
Are you talking about these gauges?
- Fraggboy
- Software: Bloomsky
Re: Live Gauges API
He's talking about the livegaugesAPI plugin. These gauges are a plugin, and not a block.
- stadelhofen
Re: Live Gauges API
No, about these: http://meteo.ksstadelhofen.ch/template/ ... index1.php
I woud like to implement them in the homepage
- jay_hoehn
- Language Admin
- Software: WeeWx
Re: Live Gauges API
That can not be done. That is a plugin and not a block to be added to the home page.
Jay
Jay
- stadelhofen
Re: Live Gauges API
but how come, that the STEELSERIES GAUGES, which are also Plugins, can be implemented in the homepage, this does not make sence
- nikokara - BANNED
- Johnny
- Developer
Re: Live Gauges API
I'm pretty sure Jay is 100% correct here, this is a plugin only having it's own page - I've always thought they look pretty cool. Maybe they can't be used as a block due to their size, you might have to wait for Jachym to give you a definitive answer on this.
Re: Live Gauges API
Your page showed just an error from Chrome. My page is http, but shows fine.stadelhofen wrote: ↑Thu Oct 05, 2017 3:58 pm and when do you implement SSL for http://www.meteotemplate.com ?
you wrote: I think you should first fix this because if your web is inaccessible from the most widely used browser it is a serious issue...![]()
Re: Live Gauges API
Steelseries gauges have a plugin and a block, no plugin can be displayed on the homepage unless it is also a block.
The only problem with https you might have is that your server might not like communication with mine, which is http, so you wont see latest versions etc., but your page will work fine.
