forecastAU Bug
martymoose
Station model: Maxion
Software: Weewx
forecastAU Bug
Post by martymoose » Mon Nov 06, 2017 7:32 pm
as per screenshot Queensland is represented by QLD but on the forecast its QSL
IF I enter QLD or QSL the forecast always defaults to NSW
also tried TAS as well still stuck on NSW towns
PS NSW, TAS and QLD are states (regions)
Re: forecastAU Bug
Post by Jachym » Mon Nov 06, 2017 8:21 pm
Whenever you make such change make sure you delete the cache file, otherwise it will be loading the original cached data until the cache expires (usually a few hours)
Re: forecastAU Bug
Post by Jachym » Mon Nov 06, 2017 8:57 pm
The abbr. for Queensland to be used is QSL I checked the block code now, but make sure you also delete the cache
