Snow Block: Comments display issue
Post by MonyMony » Sun Dec 10, 2017 5:42 pm
When using the snow block and adding the comment '0.28" melted', the block appears to have problems with the double-quote which just so happens is also a short-hand way to represent inches.
Screen Shot 2017-12-10 at 12.33.34 PM.png (17.54 KiB) Viewed 5124 times
I can work-around this by just writing 'in' instead of the double-quote but wanted to put the alert to the display issue.
Re: Snow Block: Comments display issue
Post by MonyMony » Mon Dec 11, 2017 12:52 pm
Just to add it looks like the problem is how the information is getting added to SQL:
Screen Shot 2017-12-11 at 7.51.05 AM.png (91.65 KiB) Viewed 5107 times
Post by Jachym » Mon Dec 11, 2017 9:13 pm
Try using HTML codes instead
https://www.ascii.cl/htmlcodes.htm
Post by MonyMony » Tue Dec 12, 2017 2:03 pm
Jachym wrote: Mon Dec 11, 2017 9:13 pm Try using HTML codes instead
I will give that a shot.
Also noticed that the comments for the current day is with the "Depth" but for yesterday it is with the "Snowfall". Minor but these should probably by consistent on where they are associated, either both with the snowfall or the total depth.
Screen Shot 2017-12-12 at 8.59.33 AM.png (24.57 KiB) Viewed 5080 times
Post by MonyMony » Tue Dec 12, 2017 2:18 pm
No joy... code just gets dropped when you click SAVE.
