Block names in menuBlock
ChrisBoom
Post by ChrisBoom » Wed Dec 27, 2017 5:51 pm
Hello all,
I've shrunk my one-column mobile page by sectioning and grouping certain blocks into menuBlocks, which works nicely. If I understand the wiki correctly, the names for the blocks in a menuBlock are auto-translated (if possible). This seems to work for some of the block names (like 'riset' is properly translated into Sonnenauf/untergang). Some, however, remain untranslated and do not make much sense in German (like 'dayPie'). It's clear to us what that is, but many visitors of the site may have no clue.
Is there a way to name the blocks manually or at least append a German explanation on what they do?
Thanks and best regards
Chris
Re: Block names in menuBlock
Post by Jachym » Wed Dec 27, 2017 8:07 pm
If they are not translated it means they are not in the language database, post them here and I will add them. You cannot do this manually.
ChrisBoom
Post by ChrisBoom » Thu Dec 28, 2017 10:03 am
The blocks I use and their German translations are:
radarDE - Regenradar Deutschland
radarNL - Regenradar Niederlande
lightning - Gewitterradar
windRose - Windrose/Windrichtung
dayPie - Kreisdiagramm Tageswerte
dailyDeviations - Abweichungen (täglich)
Thanks a lot Jachym! That's very helpful and I can make full use of the menuBlock functionality. It's a great feature that helps to keep the homepage compact.
Best regards
Chris
Post by Jachym » Thu Dec 28, 2017 10:25 am
ok added
ChrisBoom
Post by ChrisBoom » Mon Jan 15, 2018 10:19 am
Thank you Jachym!
Unfortunately, the names still don't show up in the menu when I open it. I've downloaded the current language file for German and I'm on v17. Where am I doing it wrong? Do I need to remove and re-install the blocks?
Cheers
Chris
Post by Jachym » Mon Jan 15, 2018 1:17 pm
which ones, all of them?
ChrisBoom
Post by ChrisBoom » Thu Jan 18, 2018 4:31 pm
Yes, the ones I translated are still in the menu.
Same for dayPie etc... :?:
