WIndy
Jeffm5690
WIndy
Post by Jeffm5690 » Thu Jan 11, 2018 12:18 am
I have an odd issue. I installed the Windy block and in block setup it shows the update icon, my homepage shows the update icon, and I can't get the block to appear on my page.
Any ideas?
Jeff
Re: WIndy
Post by Jachym » Thu Jan 11, 2018 12:47 am
Could be caching issue, just wait and if it does not fix itself tomorrow email me
Jeffm5690
Re: WIndy
Post by Jeffm5690 » Thu Jan 11, 2018 12:48 am
Thanks Jachym!
dmgould
Re: WIndy
Post by dmgould » Thu Jan 11, 2018 2:30 am
Windy block shows on my page. When I log in the version checker tells me I need to update the block. When I go to the block setup it shows I am using version 0.0 and update 1.0 is available. There also seems to be a namespace issue in that it doesn't come up in the homepage setup, but when the namespace is typed in the block works for me.
Jeffm5690
Re: WIndy
Post by Jeffm5690 » Thu Jan 11, 2018 2:43 am
I have the same problem except the block doesn’t show. I’ll wait and see what happens tomorrow.
dmgould
Re: WIndy
Post by dmgould » Thu Jan 11, 2018 2:46 am
I edited my last post. Are you using namespace 'windy' on the homepage setup? When I use that the block works. But, the version checker is still incorrect.
Jeffm5690
Re: WIndy
Post by Jeffm5690 » Thu Jan 11, 2018 3:15 am
Working now except for the update as showing as needed and the version being 0.0 like yours.
dmgould
Re: WIndy
Post by dmgould » Thu Jan 11, 2018 3:36 am
Good deal. Now hopefully Jachym can figure out the version problem we are both seeing.
StSampsonsMarina
Software: Meteobridge Pro
Re: WIndy
Post by StSampsonsMarina » Thu Jan 11, 2018 5:14 am
I think the issue is that there is a missing " in the windyConfig.txt file, right after the word map.
Currently
{"version":1.0,"name":"Windy map,"namespace":"windy"}
I think it should be
{"version":1.0,"name":"Windy map","namespace":"windy"}
Changing that has fixed the problem for me.
dmgould
Re: WIndy
Post by dmgould » Thu Jan 11, 2018 5:28 am
Yes it is. Good catch! It's just a typo.
Re: WIndy
Post by Jachym » Thu Jan 11, 2018 11:26 am
:D thanks you are right!
I will update it
cryoxdsl
Software: API
Re: WIndy
Post by cryoxdsl » Thu Jan 11, 2018 12:32 pm
Hello everyone, I had the same problem last night.
I made the same correction.
windyConfig.txt must contain:
{"version": 1.0, "name": "Windy map", "namespace": "windy"}
Have a good day.
Re: WIndy
Post by Jachym » Thu Jan 11, 2018 2:39 pm
Update available :)
Jeffm5690
Re: WIndy
Post by Jeffm5690 » Thu Jan 11, 2018 2:48 pm
Thanks Jachym. Will have to wait until I am at a computer to manually upload.
WessexWeather
Re: WIndy
Post by WessexWeather » Sat Jan 13, 2018 9:35 am
I’ve noticed that when you press play to the left of the timeline at the bottom of the map the relevant dates and times are not displayed on a mobile device. This is the same within the block and the new bootstrap mobile page.
For example if I view this block on an iPad the times show correctly, but are missing on an iPhone. Similarly on an iPad you can click or scroll the timeline to jump along but this isn’t the case on my phone.
Simon (WessexWeather)
Re: WIndy
Post by Jachym » Sat Jan 13, 2018 12:43 pm
this is a Windy widget, the actual content of the widget is 100% under control of Windy page, so if there is a bug like this you would need to email them
