Extreme Block 1970
Saszalez
- Software: WeatherLink
Extreme Block 1970
Hello. I have installed the "Extremes Block", and when looking at the list, the first minimum value of any of the variables is 0, registered on January 1, 1970. There is no value for that date; it is always 0. How can it be corrected?
- Captura de pantalla 2022-03-28 a las 12.13.40.png (23.76 KiB) Viewed 6171 times
Re: Extreme Block 1970
You can remove this erroneous data ( via the meteotemplate control panel ) database -> edit data and database -> edit data extra sensors, remove any data of 01/01/1970 ( it should be only one ).
If you have several of these wrong data it could be faster to remove them via phpmyadmin ( accessibkle via your hosting provider's control panel )
Saszalez
I have looked where you have told me, and there is no data. Therefore, I cannot delete anything.
I see.
To pinpoint the problem you can try executing the following query ( in phpmyadmin ):
This is the same query that is executed to retrieve minimum average temperature:
SELECT DayAvg, DATETIME
FROM (
SELECT DATETIME, AVG(T) AS DayAvg
FROM alldata
GROUP BY YEAR(DATETIME), MONTH(DATETIME), DAY(DATETIME)
ORDER BY DATETIME
) AS DailyMaxTable
ORDER BY DayAvg
LIMIT 10-
Saszalez
If I run the code I get the following:
- Captura de pantalla 2022-03-28 a las 23.25.41.png (37.19 KiB) Viewed 6152 times
I'd say you have a record on 1970-01-01
This query ( in phpmyadmin ) should return exactly 1 result:
And this query should delete it:
Is always a good idea to make a backup of the database before executing these ( potentially destructive ) queries
SELECT * FROM `alldata` WHERE DateTime <= '2020-01-01 00:00:00'Code: Select all
DELETE FROM `alldata` WHERE DateTime <= '2020-01-01 00:00:00'Is always a good idea to make a backup of the database before executing these ( potentially destructive ) queries
