Extreme Block 1970
Saszalez
Software: WeatherLink
Extreme Block 1970
Post by Saszalez » Mon Mar 28, 2022 11:20 am
Hello. I have installed the "Extremes Block", and when looking at the list, the first minimum value of any of the variables is 0, registered on January 1, 1970. There is no value for that date; it is always 0. How can it be corrected?
Captura de pantalla 2022-03-28 a las 12.13.40.png (23.76 KiB) Viewed 6177 times
Re: Extreme Block 1970
Post by davidefa » Mon Mar 28, 2022 12:49 pm
You can remove this erroneous data ( via the meteotemplate control panel ) database -> edit data and database -> edit data extra sensors, remove any data of 01/01/1970 ( it should be only one ).
If you have several of these wrong data it could be faster to remove them via phpmyadmin ( accessibkle via your hosting provider's control panel )
Saszalez
Post by Saszalez » Mon Mar 28, 2022 6:14 pm
I have looked where you have told me, and there is no data. Therefore, I cannot delete anything.
Post by davidefa » Mon Mar 28, 2022 9:17 pm
I see.
To pinpoint the problem you can try executing the following query ( in phpmyadmin ):
SELECT DayAvg, DATETIME
			FROM (
				SELECT DATETIME, AVG(T) AS DayAvg
				FROM alldata
				GROUP BY YEAR(DATETIME), MONTH(DATETIME), DAY(DATETIME)
				ORDER BY DATETIME
			) AS DailyMaxTable
			ORDER BY DayAvg
			LIMIT 10
This is the same query that is executed to retrieve minimum average temperature:
Saszalez
Post by Saszalez » Mon Mar 28, 2022 10:26 pm
If I run the code I get the following:
Captura de pantalla 2022-03-28 a las 23.25.41.png (37.19 KiB) Viewed 6158 times
Post by davidefa » Tue Mar 29, 2022 9:28 am
I'd say you have a record on 1970-01-01
This query ( in phpmyadmin ) should return exactly 1 result:
SELECT * FROM `alldata` WHERE DateTime <= '2020-01-01 00:00:00'
And this query should delete it:
DELETE FROM `alldata` WHERE DateTime <= '2020-01-01 00:00:00'
Is always a good idea to make a backup of the database before executing these ( potentially destructive ) queries
