minor problems with php 8.1
Post by meteoesine » Thu Aug 25, 2022 12:35 pm
found the following:
if you modify a field in the Database Editing - Extra Sensors, when you reload the page the previous data is shown (modification not made). ok instead if you delete the entire record.
plugin stationExtremes:
https://meteoesine.it/template/plugins/ ... onthly.php
Deprecated: number_format(): Passing null to parameter #1 ($num) of type float is deprecated in /home/cldvlwax/public_html/template/plugins/stationExtremes/monthly.php on line 44
Deprecated: number_format(): Passing null to parameter #1 ($num) of type float is deprecated in /home/cldvlwax/public_html/template/plugins/stationExtremes/monthly.php on line 62
https://meteoesine.it/template/plugins/ ... /daily.php
Deprecated: number_format(): Passing null to parameter #1 ($num) of type float is deprecated in /home/cldvlwax/public_html/template/plugins/stationExtremes/daily.php on line 56
Deprecated: number_format(): Passing null to parameter #1 ($num) of type float is deprecated in /home/cldvlwax/public_html/template/plugins/stationExtremes/daily.php on line 75
plugin: windDirection
https://meteoesine.it/template/plugins/ ... lector.php
periodic graph (both wind and gust) when selecting a period greater than 1 day it freezes
https://meteoesine.it/template/pages/st ... ndices.php
does not work (blank page)
Re: minor problems with php 8.1
Post by davidefa » Thu Aug 25, 2022 8:46 pm
I've updated your pages.
Regarding the database editing that fails, I noticed that too, it should fail when editing a line with null values ( I should have corrected in this admin mod: viewtopic.php?f=51&t=2298#p11653, did not install in your server )
Post by meteoesine » Fri Aug 26, 2022 5:37 am
tnx u very much
Post by meteoesine » Thu Sep 01, 2022 5:53 pm
It's not a problem, but just a clarification:
my alldataExtra database was created in May,
in the statistics .../template/pages/station/climate.php?var=xxx it displays 0 although it should be null
there are no 0 values, is that correct?
tnx
Post by davidefa » Thu Sep 01, 2022 8:59 pm
Yes, null values should not be treated as 0 values ( noticed this even in other blocks pages ).
Post by meteoesine » Sun Jan 08, 2023 7:42 am
happy new year to all the forum
I noticed that in the rain statistics (only that), selecting by year, it displays only that of 2014 while all the others (all months) are displayed correctly,
https://meteoesine.it/template/pages/st ... .php?var=R
some idea?
thank you
Jolumarali
Station model: Vantage Vue
Software: WlIP
Post by Jolumarali » Sun Jan 08, 2023 10:22 am
good morning
No problem for me, I'm still on PHP 7.4 !
FSC830
Post by FSC830 » Sat Jan 21, 2023 11:20 pm
meteoesine wrote: Sun Jan 08, 2023 7:42 am happy new year to all the forum
some idea?
thank you
how did you fix that?
Having the same issue here :shock: , only an empty 1970 is displayed.
Edit: Forget the question, just checked again and now all years are displayed. When I called this page earlier this day only 1970 was showed up. Strange... self healing mystery of data :D (or it did take some time).
Post by meteoesine » Mon Jan 23, 2023 3:51 pm
as far as I'm concerned it's a matter of php 8.1 ... putting back 7.4 it works correctly (so while it still goes, I keep that ;) )
FSC830
Post by FSC830 » Mon Jan 23, 2023 8:35 pm
Ah, thats why it actually shows all years, you are back to 7.4 :D .
But as written above in my edit, it was fixed after some hours.
I am still running now at PHP 8.1.14.
