minor problems with php 8.1
- meteoesine
- Station model: Davis Pro2+
- Software: Meteobridge nano
found the following:
if you modify a field in the Database Editing - Extra Sensors, when you reload the page the previous data is shown (modification not made). ok instead if you delete the entire record.
plugin stationExtremes:
https://meteoesine.it/template/plugins/ ... onthly.php
Deprecated: number_format(): Passing null to parameter #1 ($num) of type float is deprecated in /home/cldvlwax/public_html/template/plugins/stationExtremes/monthly.php on line 44
Deprecated: number_format(): Passing null to parameter #1 ($num) of type float is deprecated in /home/cldvlwax/public_html/template/plugins/stationExtremes/monthly.php on line 62
https://meteoesine.it/template/plugins/ ... /daily.php
Deprecated: number_format(): Passing null to parameter #1 ($num) of type float is deprecated in /home/cldvlwax/public_html/template/plugins/stationExtremes/daily.php on line 56
Deprecated: number_format(): Passing null to parameter #1 ($num) of type float is deprecated in /home/cldvlwax/public_html/template/plugins/stationExtremes/daily.php on line 75
plugin: windDirection
https://meteoesine.it/template/plugins/ ... lector.php
periodic graph (both wind and gust) when selecting a period greater than 1 day it freezes
https://meteoesine.it/template/pages/st ... ndices.php
does not work (blank page)
Re: minor problems with php 8.1
I've updated your pages.
Regarding the database editing that fails, I noticed that too, it should fail when editing a line with null values ( I should have corrected in this admin mod: viewtopic.php?f=51&t=2298#p11653, did not install in your server )
- meteoesine
- meteoesine
It's not a problem, but just a clarification:
my alldataExtra database was created in May,
in the statistics .../template/pages/station/climate.php?var=xxx it displays 0 although it should be null
there are no 0 values, is that correct?
tnx
tnx
- ScreenShot01141.jpg (29.15 KiB) Viewed 9591 times
- ScreenShot01139.jpg (37.96 KiB) Viewed 9591 times
- ScreenShot01142.jpg (22.73 KiB) Viewed 9591 times
Yes, null values should not be treated as 0 values ( noticed this even in other blocks pages ).
- meteoesine
happy new year to all the forum
I noticed that in the rain statistics (only that), selecting by year, it displays only that of 2014 while all the others (all months) are displayed correctly,
https://meteoesine.it/template/pages/st ... .php?var=R
some idea?
thank you
some idea?
thank you
- 2023-01-08_083244.png (21.01 KiB) Viewed 9158 times
- Jolumarali
- Station model: Vantage Vue
- Software: WlIP
good morning
No problem for me, I'm still on PHP 7.4 !
FSC830
Hi,meteoesine wrote: ↑Sun Jan 08, 2023 7:42 am happy new year to all the forum
some idea?
thank you
how did you fix that?
Having the same issue here
Edit: Forget the question, just checked again and now all years are displayed. When I called this page earlier this day only 1970 was showed up. Strange... self healing mystery of data
- meteoesine
as far as I'm concerned it's a matter of php 8.1 ... putting back 7.4 it works correctly (so while it still goes, I keep that
FSC830
Ah, thats why it actually shows all years, you are back to 7.4
But as written above in my edit, it was fixed after some hours.
I am still running now at PHP 8.1.14.
