RESOLVED: Desktop Homepage Layout Problems
cw3beck
Post by cw3beck » Tue Nov 11, 2025 7:09 pm
Have been using Meteotemplate for many years and this problem just started happening this morning:
When my Homepage is displayed, the layout looks to be constrained (ie. the blocks are too big to correctly fit in the allocated column width). See attached Homepage snipit.
However, when I click on a menu item, the layout looks correct. See "correct layout" attachment.
I've tried other browsers to rule out a nuance between browsers as well as using a different version of PHP neither of which provides a different result. I haven't made any changes to my control files or home page settings but it almost looks like the template thinks that my one column that I'm using is smaller than it actually is.
Interestingly, when the homepage initially loads, it displays correctly for a couple of seconds then gets constrained. I also noticed that the links to my first 4 menu items are not accessible from the homepage but ARE accessible if you bring them up threw one of the other menus.
If you have any ideas as to where to start troubleshooting, I'd really appreciate it.
https://eaglerisingwx.synology.me/indexDesktop.php
Homepage Problem
Homepage Problem
correct layout
correct layout
meteoparquecoimbra
Station model: WMR928NX, Oregon Scientic
Software: Virtual Weather Station
Re: Desktop Homepage Layout Problems
Post by meteoparquecoimbra » Wed Nov 12, 2025 8:54 am
Estoy igual, cuando se carga la pagina en pc hay 1 segundo que se ve bien pero inmediatamente parece que se va a la version movil de una columna. Esperando soluciones
meteoparquecoimbra
Post by meteoparquecoimbra » Wed Nov 12, 2025 9:45 am
Yo ya he solucionado el problema, en mi caso el problema lo daba el bloque GFS de la configuracion PC, lo he quitado y ya esta funcionando.
Saludos
cw3beck
Post by cw3beck » Wed Nov 12, 2025 7:17 pm
Gracias, probaré eso también, ya que yo también tengo el bloque GFS en mi página de inicio. Gracias.
cw3beck
Post by cw3beck » Wed Nov 12, 2025 7:20 pm
meteoparquecoimbra wrote: Wed Nov 12, 2025 9:45 am Yo ya he solucionado el problema, en mi caso el problema lo daba el bloque GFS de la configuracion PC, lo he quitado y ya esta funcionando.
Saludos
¡Eres el HOMBRE, Señor! Funcionó a la perfección.
meteopuerto
Station model: Wittboy
Re: RESOLVED: Desktop Homepage Layout Problems
Post by meteopuerto » Fri Nov 21, 2025 10:30 pm
Gracias, me tenía loco el tema.
Era el bloque GFS... desactivado y ya funciona bien.
De nuevo, gracias!!
