Have been using Meteotemplate for many years and this problem just started happening this morning:
When my Homepage is displayed, the layout looks to be constrained (ie. the blocks are too big to correctly fit in the allocated column width). See attached Homepage snipit.
However, when I click on a menu item, the layout looks correct. See "correct layout" attachment.
I've tried other browsers to rule out a nuance between browsers as well as using a different version of PHP neither of which provides a different result. I haven't made any changes to my control files or home page settings but it almost looks like the template thinks that my one column that I'm using is smaller than it actually is.
Interestingly, when the homepage initially loads, it displays correctly for a couple of seconds then gets constrained. I also noticed that the links to my first 4 menu items are not accessible from the homepage but ARE accessible if you bring them up threw one of the other menus.
If you have any ideas as to where to start troubleshooting, I'd really appreciate it.
https://eaglerisingwx.synology.me/indexDesktop.php
RESOLVED: Desktop Homepage Layout Problems
cw3beck
- Station model: Davis Pro 2
- Homepage Problem
- Homepage_snipit.png (381.06 KiB) Viewed 9011 times
- correct layout
- correct_snipit.png (486.28 KiB) Viewed 9011 times
meteoparquecoimbra
- Station model: WMR928NX, Oregon Scientic
- Software: Virtual Weather Station
Re: Desktop Homepage Layout Problems
Estoy igual, cuando se carga la pagina en pc hay 1 segundo que se ve bien pero inmediatamente parece que se va a la version movil de una columna. Esperando soluciones
meteoparquecoimbra
Yo ya he solucionado el problema, en mi caso el problema lo daba el bloque GFS de la configuracion PC, lo he quitado y ya esta funcionando.
Saludos
Saludos
cw3beck
Gracias, probaré eso también, ya que yo también tengo el bloque GFS en mi página de inicio. Gracias.
cw3beck
¡Eres el HOMBRE, Señor! Funcionó a la perfección.meteoparquecoimbra wrote: ↑Wed Nov 12, 2025 9:45 am Yo ya he solucionado el problema, en mi caso el problema lo daba el bloque GFS de la configuracion PC, lo he quitado y ya esta funcionando.
Saludos
meteopuerto
- Station model: Wittboy
Re: RESOLVED: Desktop Homepage Layout Problems
Gracias, me tenía loco el tema.
Era el bloque GFS... desactivado y ya funciona bien.
De nuevo, gracias!!
De nuevo, gracias!!
