Gfs: starting map
Gfs: starting map
Post by meteoesine » Sat Aug 26, 2017 6:04 pm
I've installed GFS block on my homepage, set to start with a map, but always is displayed that of the temperature as default.
Is there any possibility to change the default map - for example 'overview' or another one instead of the temperature?
thanks in advance for any comments.
bye
Norbert
Re: Gfs: starting map
Post by Jachym » Sat Aug 26, 2017 9:49 pm
In gfsBlock.php find this line (454)
<img src="http://wxcharts.eu/charts/gfs/<?php echo $selectRegion?>/<?php echo $latestData?>/2mtemp_003.jpg?<?php echo time()?>" id="gfsMainMap" onclick="zoomGFS()">
Change the 2mtemp to overview
Post by meteoesine » Sun Aug 27, 2017 5:26 am
thanks a lot
georg
Station model: Davis Pro 2+
Post by georg » Sun Aug 27, 2017 7:40 am
Super :D :D :D
Just what i have been looking for.
Anywhere i can change this to overview instead of temp?
also using the slider in the bottom it will shift from overview to temperature.
Post by meteoesine » Mon Aug 28, 2017 8:10 am
Yes, I agree.
changing only the image is not enough: it does not well running
is it possible to modify the entire block using 'overview' (image and match code) as default instead of tempertature?
thanks in advance
Post by Jachym » Mon Aug 28, 2017 9:18 am
You need to move the "selected" attribute from the "temp" option to the "overview" option so that it shows as selected in the select box as well
georg
Post by georg » Mon Aug 28, 2017 9:47 am
Done !!!
Thanks a lot ----- fantastic and fast support :D :D :D :D
Post by meteoesine » Mon Aug 28, 2017 9:55 am
excellent !!
tnx
Post by meteoesine » Fri Sep 14, 2018 11:31 am
I have gfsMapSelector selected as default "Italy", can you pls explain how I can change the default as "Europe" ?
many thanks in advance
