Gfs: starting map
- meteoesine
- Station model: Davis Pro2+
- Software: Meteobridge nano
Gfs: starting map
I've installed GFS block on my homepage, set to start with a map, but always is displayed that of the temperature as default.
Is there any possibility to change the default map - for example 'overview' or another one instead of the temperature?
thanks in advance for any comments.
bye
Norbert
bye
Norbert
Re: Gfs: starting map
In gfsBlock.php find this line (454)
Change the 2mtemp to overview
<img src="http://wxcharts.eu/charts/gfs/<?php echo $selectRegion?>/<?php echo $latestData?>/2mtemp_003.jpg?<?php echo time()?>" id="gfsMainMap" onclick="zoomGFS()">- meteoesine
- georg
- Station model: Davis Pro 2+
Super
Just what i have been looking for.
Anywhere i can change this to overview instead of temp?
also using the slider in the bottom it will shift from overview to temperature.
- meteoesine
Yes, I agree.
changing only the image is not enough: it does not well running
is it possible to modify the entire block using 'overview' (image and match code) as default instead of tempertature?
thanks in advance
thanks in advance
You need to move the "selected" attribute from the "temp" option to the "overview" option so that it shows as selected in the select box as well
- meteoesine
- meteoesine
I have gfsMapSelector selected as default "Italy", can you pls explain how I can change the default as "Europe" ?
many thanks in advance
- ScreenShot00303.jpg (39.37 KiB) Viewed 15915 times
