Interactive Graph Time
- Dehatter
- Station model: Ecowitt WH80
- Software: Ecowitt GW1000
I maybe doing something wrong (as it seems in my past problems) but on my site, the time in the interactive graph shows 5 hrs earlier than the actual time the reading is taken.
- Current.jpg (98.51 KiB) Viewed 29547 times
- graphtime.jpg (25.9 KiB) Viewed 29547 times
RobF
- Station model: Davis Pro 2 Plus
- Software: WeatherLink.com
Re: Interactive Graph Time
Mine is doing that as well. I don't see a way to set the time or time zone for this block.
RobF
Just saw the previous thread regarding this:
viewtopic.php?f=56&t=653
Yea, the full screen has the correct times, just the block is off (5 hours here where we are here).
Any progress or ideas?
- jay_hoehn
- Language Admin
- Station model: Vantage Pro 2 Plus
- Software: WeeWx
Interesting. Your full screen time is correct. Mine displays the same as in the block.
Jay
http://www.jayswoodfurniture.com/meteo/indexDesktop.php
Jay
- Fraggboy
- Station model: Bloomsky II + Storm
- Software: Bloomsky
Both Current and Interactive blocks are showing the correct time for my site. I have no idea as to what would cause that issue.. :/
Current Block: Interactive Block:
- Dehatter
This is weird. When I check Jay’s station it was off by 5 hours like mine, but Fraggboy’s is indeed correct. Not sure why his would be different from the rest. A time zone selection issue? Gonna check into that.
Im 100% sure it worked fine before, surely people would notice if all graphs had incorrect times. It is strange that it only occurs for some, they must have changed something in the Highcharts script, it is loaded from the central CDN, so it always uses the latest version automatically
- Dehatter
I can confirm that changing the time zone does not affect the time on the graph. To add to the confusion, it is correct in the graph shown using fixed bootstrap setup.
the mobile site uses the exact same script as the interactive graph, the exact same time processing
- Dehatter
all I know is that something is different.
Something about the axis generation. The label comes from the axis.
Also has something to do with time zones because your site is +1 hr and mine is -5 hours. Which is how far we are from UTC.
Try removing all other blocks on the page that are using Highcharts.
The problem is that for me it works fine on my page, so it is problematic to fix something that seems to be "fixed" from my side
The graph on this site: http://www.meteotemplate.com/template/indexDesktop.php is one hour ahead?
- Dehatter
This is what it shows for me.
- graphtimeBrno.jpg (99.24 KiB) Viewed 29399 times
- currentBrno.jpg (75.58 KiB) Viewed 29399 times
OK,
here is the bad news:
The highcharts script is not loaded from your server, but from the CDN which means always the latest version is used. Some change must have been made in HCh, because it affects more pages and I would 100% notice it and not release it if the times were wrong. Looking at the documentation, the recent new version (6.0) has no changes in terms of time handling so it will be complicated to try to find what is causing it.
Good news:
I can see the problem on my page as well, which gives me a chance to try to play around with it
Good news:
OK, so to make things even more mysterious... the EXACT same script (loaded from the same location) loads differently on its own and when on the homepage, can someone verify this?
http://www.meteotemplate.com/template/i ... ctiveGraph
- jay_hoehn
- Language Admin
- Software: WeeWx
Jachym,
I can confirm the problem. On the stand alone block the last datapoint reads 15:10 on the full page it reads 23:10.
Jay
Jay
OK try now please
(it is 10:32 PM, thats what it should show on my page)
- jay_hoehn
- Language Admin
- Software: WeeWx
Jachym,
Now both read 22:34 for me. Maybe you found the issue?
Jay
Jay
Yes, I did make some changes, works for me as well
- jay_hoehn
- Language Admin
- Software: WeeWx
Jachym,
Will you be releasing a fix?
Jay
Jay
Hopefully yes, but I need to test it a bit more before releasing it to make absolutely sure it is working
