Interactive Graph Time
Post by Dehatter » Mon Jan 15, 2018 5:50 pm
I maybe doing something wrong (as it seems in my past problems) but on my site, the time in the interactive graph shows 5 hrs earlier than the actual time the reading is taken.
RobF
Software: WeatherLink.com
Re: Interactive Graph Time
Post by RobF » Wed Jan 17, 2018 7:45 pm
Mine is doing that as well. I don't see a way to set the time or time zone for this block.
RobF
Post by RobF » Wed Jan 17, 2018 7:52 pm
Just saw the previous thread regarding this:
viewtopic.php?f=56&t=653
Yea, the full screen has the correct times, just the block is off (5 hours here where we are here).
Any progress or ideas?
jay_hoehn
Software: WeeWx
Post by jay_hoehn » Wed Jan 17, 2018 8:26 pm
Interesting. Your full screen time is correct. Mine displays the same as in the block.
Jay
http://www.jayswoodfurniture.com/meteo/indexDesktop.php
Fraggboy
Software: Bloomsky
Post by Fraggboy » Wed Jan 17, 2018 9:36 pm
Both Current and Interactive blocks are showing the correct time for my site. I have no idea as to what would cause that issue.. :/
Current Block:
current conditions.jpg (34.02 KiB) Viewed 29516 times
Interactive Block:
Interactive graph.jpg (39.8 KiB) Viewed 29516 times
Post by Jachym » Thu Jan 18, 2018 5:00 am
:D yes, same for me, this is very odd
Post by Dehatter » Thu Jan 18, 2018 9:09 pm
This is weird. When I check Jay’s station it was off by 5 hours like mine, but Fraggboy’s is indeed correct. Not sure why his would be different from the rest. A time zone selection issue? Gonna check into that.
Post by Jachym » Thu Jan 18, 2018 9:10 pm
Im 100% sure it worked fine before, surely people would notice if all graphs had incorrect times. It is strange that it only occurs for some, they must have changed something in the Highcharts script, it is loaded from the central CDN, so it always uses the latest version automatically
Post by Dehatter » Thu Jan 18, 2018 9:28 pm
I can confirm that changing the time zone does not affect the time on the graph. To add to the confusion, it is correct in the graph shown using fixed bootstrap setup.
Post by Dehatter » Thu Jan 18, 2018 9:34 pm
Additionally when I check yours Jachym, it is off by 1 hour.
Post by Jachym » Fri Jan 19, 2018 7:47 am
the mobile site uses the exact same script as the interactive graph, the exact same time processing
Post by Dehatter » Fri Jan 19, 2018 2:56 pm
all I know is that something is different.
Something about the axis generation. The label comes from the axis.
Also has something to do with time zones because your site is +1 hr and mine is -5 hours. Which is how far we are from UTC.
droiddk
Post by droiddk » Fri Jan 19, 2018 4:24 pm
Try removing all other blocks on the page that are using Highcharts.
Post by Jachym » Fri Jan 19, 2018 6:09 pm
The problem is that for me it works fine on my page, so it is problematic to fix something that seems to be "fixed" from my side
droiddk
Post by droiddk » Fri Jan 19, 2018 6:53 pm
Jachym wrote: Fri Jan 19, 2018 6:09 pm The problem is that for me it works fine on my page, so it is problematic to fix something that seems to be "fixed" from my side
The graph on this site: http://www.meteotemplate.com/template/indexDesktop.php is one hour ahead?
Post by Dehatter » Fri Jan 19, 2018 8:45 pm
This is what it shows for me.
Post by Jachym » Fri Jan 19, 2018 9:09 pm
OK,
here is the bad news:
The highcharts script is not loaded from your server, but from the CDN which means always the latest version is used. Some change must have been made in HCh, because it affects more pages and I would 100% notice it and not release it if the times were wrong. Looking at the documentation, the recent new version (6.0) has no changes in terms of time handling so it will be complicated to try to find what is causing it.
Good news:
I can see the problem on my page as well, which gives me a chance to try to play around with it
Post by Jachym » Fri Jan 19, 2018 9:14 pm
OK, so to make things even more mysterious... the EXACT same script (loaded from the same location) loads differently on its own and when on the homepage, can someone verify this?
http://www.meteotemplate.com/template/i ... ctiveGraph
jay_hoehn
Software: WeeWx
Post by jay_hoehn » Fri Jan 19, 2018 9:20 pm
Jachym,
I can confirm the problem. On the stand alone block the last datapoint reads 15:10 on the full page it reads 23:10.
Jay
Post by Jachym » Fri Jan 19, 2018 9:32 pm
OK try now please
(it is 10:32 PM, thats what it should show on my page)
jay_hoehn
Software: WeeWx
Post by jay_hoehn » Fri Jan 19, 2018 9:42 pm
Jachym,
Now both read 22:34 for me. Maybe you found the issue?
Jay
Post by Jachym » Fri Jan 19, 2018 10:08 pm
Yes, I did make some changes, works for me as well
jay_hoehn
Software: WeeWx
Post by jay_hoehn » Fri Jan 19, 2018 10:27 pm
Jachym,
Will you be releasing a fix?
Jay
Post by Jachym » Fri Jan 19, 2018 11:38 pm
Hopefully yes, but I need to test it a bit more before releasing it to make absolutely sure it is working
droiddk
Post by droiddk » Sat Jan 20, 2018 4:32 pm
Jachym wrote: Fri Jan 19, 2018 11:38 pm Hopefully yes, but I need to test it a bit more before releasing it to make absolutely sure it is working
When sure, please tell us what caused this mysterious thing...
