updated ecowittModules block
Post by davidefa » Sun May 09, 2021 10:13 am
ver 1.4b
Minor update: corrected WS80, WS68 and WS65 sensor name
ver 1.4a
I have updated the ecowittModule block ( by raffaello Di Martino ) to include the following:
- updated the ecowitt sensor list
- match battery reports from the updated ecowitt module v2.6 or later
- added a couple of options to name the gateway and select the main wireless sensor
NOTE
To use this block you need to update the ecowitt plugin to v2.6 or later
NOTE1
The rf strength indication is 'fake', currently no rf reception level is reported by the sensors...
ecowittModules_1.4b.zip
(4 KiB) Downloaded 1268 times
ecowittModules_1.4a.zip
(4 KiB) Downloaded 1158 times
Re: updated ecowittModule block
Post by davidefa » Sun Oct 10, 2021 9:39 pm
ver 1.4c
Minor update:
- corrected wh25, wh31, ws65 low battery indication ( it was 75% )
- added sensor name redefinition
ecowittModules_1.4c.zip
(4.08 KiB) Downloaded 1320 times
Daali
Station model: Ecowitt GW1002
Post by Daali » Tue Oct 12, 2021 12:54 am
Great work davidefa!
I have an ecowitt WN34S that shows up as TS1BAT. I haven't figured out the array yet to add it =). I can get it to the screen but with horrible batt and rf icons LOL.
		"WN34_1"  => array("module_name" => "WN31_1", "battery_percent" => (99-$apiData['TS1BAT'] * 0.055), "set" => $apiData['TS1BAT'],    "last_seen" => $apiData['U'], "data_type" => array("Temperature"), "firmware" => $firmware,  "rf_status" => (117 - ($apiData['TS1BAT'] * 18)) ),
{"TS1":22.89,"TS1BAT":73.4,"TS1Time":1633998551,"TS1BATTime":1633998551,"StationTime":1633998551,"FWTime":1633998551}
TS1BAT = 73.4 Ecowitt.net shows 1.42v you can see I added * 0.055 to get close, but I have no idea what I am doing.
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
WH41 PM2.5 Air Quality
WH45 PM2.5/10/Co2 Air Quality
WN34S Soil temperature
WH31SM Soil Moisture
Post by davidefa » Sat Nov 27, 2021 3:44 pm
ver 1.5
- added support for wn34, wn34, wh40 and wn1900
ecowittModules_1.5.zip
(4.25 KiB) Downloaded 1309 times
Bashy
Station model: Davis Vantage Pro2 plus
Post by Bashy » Mon Mar 28, 2022 3:00 am
Hi, can this be used if you dont have a full Ecowitt station, i only have the GW1100 hub, outdoor AQ and Lightning, ideally i would like the AQ and Lightning to work, please? I have both the plugin and this block installed but nothing doing, its in the middle, 4th block down. i fear i may have missed something simple...
https://www.brecklandweather.com/meteo/indexDesktop.php
Post by davidefa » Mon Mar 28, 2022 5:02 pm
Yes, it should work.
In the ecowitt plugin set the fourth parameter ( Url of this site api.php script ) to:
http://www.brecklandweather.com/meteo/api.php
As you can see in cache/ecowittLog.txt the relative path you are using fails ( Api result -> )
Api url -> /home/breckland/public_html/meteo/api.php?U=1648486487&P=1018.59&TIN=18.11&HIN=55&PP1=7.0&L=0&LD=5&LT=1645378640&PP1BAT=5&LBAT=5&Station=GW1100A&FW=V2.1.2
Api result ->
Forward1 ecowitt format
Forward1 url -> http://www.brecklandweather.com/pwsWD2021/ecowitt/
Forward1 nfields -> 17
Forward1 result -> 1
The only problem I see is that the gw1100 T/H/P sensors will mix with the existing ones.
To avoid this you can set the 'Rename sensors' parameter to:
P1=P;Tin1=Tin;Hin1=Hin
Post by andyk1 » Thu Nov 10, 2022 3:36 am
Ecowittmodule ver 1.5 block stops working in php 8.0. any idea's?
Post by davidefa » Sun Nov 05, 2023 12:11 pm
ver 1.6
- added support for ws90
- battery voltage expressed in volts ( for those sensors reporting volts )
It is ( should be ) compatible with php 8.2
ecowittModules_1.6.zip
(4.51 KiB) Downloaded 1094 times
Re: updated ecowittModules block
Post by andyk1 » Thu Nov 09, 2023 7:36 pm
Thank you David.
El_Viejo
Station model: Ecowitt - Netatmo
Post by El_Viejo » Wed Jul 10, 2024 4:33 pm
A few days ago I have installed a station is Ecowitt Wittboy GW 2001.
It seems to me that I have successfully configured the "ecowitt" plugin (V 3.5a), because the web page appears "online". However, the block "ecowittModules" (V 1.6) is offline.
In the image is my block configuration.
What am I doing wrong?
Please, forum experts help me to discover and correct my mistakes.
After the failure with the Netatmo plugin, I have been "fighting" with the new template configuration for several days.
Thanks in advance.
steph
Post by steph » Fri Jul 12, 2024 4:13 pm
Personally, I've always stayed on 1.0 and never had a problem.
Capture d'écran 2024-07-12 181226.png (113.79 KiB) Viewed 43408 times
El_Viejo
Post by El_Viejo » Sat Jul 13, 2024 9:00 am
I am coming to the conclusion that my error is in the plugin configuration.
spd2612
Software: Meteobridge Pro 2
Post by spd2612 » Thu Jul 31, 2025 2:25 pm
Why does my signal meter stay red and at 0
All the other indicators are displaying i am using a Gw2000 with a WS90
Davis Pro 2
Meteobridge Pro2
GW 2000
WH57 Lightning Detector
spd2612
Post by spd2612 » Fri Sep 19, 2025 4:47 pm
I removed it to many php 8.2 errors slowed my site and the percent meter stayed red at 0
Davis Pro 2
Meteobridge Pro2
GW 2000
Post by andyk1 » Mon Dec 29, 2025 7:25 pm
I don't know. I lost a bunch of symbols on mine when I just upgraded to PHP 8.2 from 8.1. My host won't let me go back to 8.1 now. My site counter broke also with 2-3 other blocks.
