Voila, when I update my home page, the Block Wind rose changes appearance, do you have any idea about this problem.
I prefer the block the first Block.
Can't reproduce on my servers, so not sure what is causing it.
Only changed the X axis precedence ( line 163 gridZIndex: 3 ).
( setting in line 163 'gridZIndex: 4' should draw the axis above the graph )
Thanks Davide
But still the same.
The weird thing is that on the Mobile home page, that doesn't happen.
this also happens on other meteotemplate sites.
Good day and thank you for your research
You could try setting ( in line 163 of file windRoseBlock.php ):
gridZIndex: 4,
This should draw the x axis above the graph ( not very nice ), but this could show if the problem is the color of the axis ( maybe it is drawn in the same color of the background, so it disappears )
I also found this curious effect that happens in a completely random way:
In my specific case, if it does not display the X-axis, the legend writings are displayed with the white color that must be;
if it displays the X-axis the color of the legend's characters changes.
mysterious mysteries
I have installed the windrose block. Is it possible to change the color of the wind speed range texts?.
In automatic mode it gives me a color not visible with the template settings.
2022-02-19 12_15_57-MeteoFabro.png (62.31 KiB) Viewed 19484 times
If i have interactiveGraph on homepage the grid lines of windRose disappear. Then if I remove interactiveGraph from homepage, grid lines of windRose reappear. Strange.
Anyway for the windRose legend text to use default color? Light and Dark theme default text color?
