Wind rose
Jolumarali
Station model: Vantage Vue
Software: WlIP
Wind rose
Post by Jolumarali » Fri Dec 03, 2021 8:49 am
Hello Davide
Voila, when I update my home page, the Block Wind rose changes appearance, do you have any idea about this problem.
I prefer the block the first Block.
Re: Wind rose
Post by davidefa » Fri Dec 03, 2021 9:49 pm
Can't reproduce on my servers, so not sure what is causing it.
Only changed the X axis precedence ( line 163 gridZIndex: 3 ).
( setting in line 163 'gridZIndex: 4' should draw the axis above the graph )
windRose_1.2h.zip
(4.71 KiB) Downloaded 664 times
Jolumarali
Software: WlIP
Re: Wind rose
Post by Jolumarali » Sat Dec 04, 2021 8:15 am
Thanks Davide
But still the same.
The weird thing is that on the Mobile home page, that doesn't happen.
this also happens on other meteotemplate sites.
Good day and thank you for your research
Re: Wind rose
Post by davidefa » Sat Dec 04, 2021 9:47 am
You could try setting ( in line 163 of file windRoseBlock.php ):
gridZIndex: 4,
This should draw the x axis above the graph ( not very nice ), but this could show if the problem is the color of the axis ( maybe it is drawn in the same color of the background, so it disappears )
Jolumarali
Software: WlIP
Re: Wind rose
Post by Jolumarali » Sat Dec 04, 2021 11:11 am
same, no change
Block modified on my page
thanks again
Re: Wind rose
Post by meteoesine » Sun Dec 05, 2021 8:57 am
I also found this curious effect that happens in a completely random way:
In my specific case, if it does not display the X-axis, the legend writings are displayed with the white color that must be;
if it displays the X-axis the color of the legend's characters changes.
mysterious mysteries :D
Jolumarali
Software: WlIP
Re: Wind rose
Post by Jolumarali » Sun Dec 05, 2021 5:21 pm
Good evening
in night mode, that happens for me too, on the other hand in day mode, no problem with the color of the characters.
Meteofabro
Software: Meteobridge RED PRO
Re: Wind rose
Post by Meteofabro » Sat Feb 19, 2022 11:37 am
I have installed the windrose block. Is it possible to change the color of the wind speed range texts?.
In automatic mode it gives me a color not visible with the template settings.
2022-02-19 12_15_57-MeteoFabro.png (62.31 KiB) Viewed 19471 times
Re: Wind rose
Post by davidefa » Sun Feb 20, 2022 12:01 am
ver 1.3
Added an option to define legend text color
windRose_1.3.zip
(4.66 KiB) Downloaded 655 times
Meteofabro
Re: Wind rose
Post by Meteofabro » Mon Feb 21, 2022 2:25 pm
Thank you :)
mchd17
Re: Wind rose
Post by mchd17 » Wed Apr 13, 2022 3:01 pm
Works well, nicely done!
mchd17
Re: Wind rose
Post by mchd17 » Sun Apr 17, 2022 4:06 pm
If i have interactiveGraph on homepage the grid lines of windRose disappear. Then if I remove interactiveGraph from homepage, grid lines of windRose reappear. Strange.
Anyway for the windRose legend text to use default color? Light and Dark theme default text color?
Re: Wind rose
Post by davidefa » Mon Apr 18, 2022 2:46 pm
Thanks for pointing in the right direction.
Don't know why, but there was an unwanted interaction with the interactiveGraph block.
ver 1.4
- corrected X grid not always showing
- corrected legend text not drawn in default color
windRose_1.4.zip
(4.72 KiB) Downloaded 731 times
mchd17
Re: Wind rose
Post by mchd17 » Mon Apr 18, 2022 10:01 pm
works good at the moment, thanks
Saszalez
Software: WeatherLink
Re: Rosa del viento
Post by Saszalez » Fri Apr 22, 2022 8:30 am
The legend's text is printed dark for me now, and it is not visible.
Captura de Pantalla 2022-04-22 a las 9.28.50.png (96.85 KiB) Viewed 19140 times
mchd17
Re: Wind rose
Post by mchd17 » Fri Apr 22, 2022 10:59 am
Same here, default color not working.
